Home Forums Terrain and Scenery 1/72 Normandy chapel and barn – Completed
This topic contains 28 replies, has 10 voices, and was last updated by 6mmwargaming 6mmwargaming 1 month ago.
Viewing 29 posts - 1 through 29 (of 29 total)
  • #74833
    6mmwargaming
    6mmwargaming
    I’ve started making a couple of 20mm scale buildings for Chain of Command. I wanted buildings with a smaller footprint than my 1/72 italeri buildings which have a big footprint on the table.
    The first building is a chapel and my inspriation was the Chapel of St Ceneri. I’m not sure if its actually in Normandy but its a nice simple design 😀
    So I started with some 5mm foamboard and model railway textured stonework sheet. I cut the baseic shape out and laminated them together. The widows are from a set of model railway buildings and although they dont look quite like chapel windows the overall shape is good. The resindoor is from Gamecraft.
    Next I cut thin beveled strips out of a foam (similar to blue foam but from a modelshop) to go around the windows and door frames. it pretty hard to see that in the picture.
    Then I assembled it and added a roof and floor from 3mm card. I cut pieces out of the ends of the walls to make it stronger and also for the floor to make it stronger.
    Onto the barn
    The idea was to have a smaller barn with a stone extension, and make the barn look a bit run down. With the barn I followed a similar construction technique, but I plan to texture the walls on the main piece. I cut the windows and doors out and used thin card to edge the frames. The doors are from Gamecraft.
    The barn door was made from balsa wood and card. I stuck to card foamboard and balsa for the buildings as it all glues together well with PVA.
    Also with this building I made a floor from card and the roof. And I have started on the roof which is made from thin card cut into strips.
    More soon.
    • This topic was modified 2 months, 3 weeks ago by 6mmwargaming 6mmwargaming.
    • This topic was modified 2 months, 2 weeks ago by 6mmwargaming 6mmwargaming.
    • This topic was modified 1 month ago by 6mmwargaming 6mmwargaming.
    #74836
    True to form sir, true to form!
    What scale / brand is the stone sheet?
    #74879
    Darkest Star Games
    Darkest Star Games
    That is a fantastic start!  Both buildings are looking really good.
    #74880
    6mmwargaming
    6mmwargaming
    Thanks guys. I’ve made more progress, I just need to sort out the photos.
    #75018
    6mmwargaming
    6mmwargaming
    No idea about the stone sheet sorry, I got it in a model railway shop and it was one of the Gemran brands.
    A small confession, I started these a couple of weeks ago so I am catching up on the progress.
    Chapel
    I added some buttresses(?) to the chapel as I noticed them in the photos and it breaks up the walls. These were carved from blue foam using a pen and knife. Later on I reduced the size of these as they looked too large.
    Also after many nights gluing cardboard on I finished the roof. The tiles were made from a mix of strips and individual tiles (with a few to glue down again!)
    More progress on the Barn. I textured the walls using acrylic caulk (sealant) and I added some details. I cut some card strips up in 5mm wide strips and folded and glued them to make the window frames and added windows from Gamecraft. The shutters and bits above the windows are spares from Italeri’s 1/72 Mediterranean style buildings. And some details on and around the barn doors.
    Also I finished the roof but it looks a little too fantasy IMHO
    More soon
    Cheers
    #75027
    Tim
    Tim
    This is really a great post.  Having never made my own buildings before I’ve bookmarked it.  I think it makes a great tutorial.
    Thanks.
    #75424
    6mmwargaming
    6mmwargaming
    I’m onto the final details for these now. I could have started painting the buildings, but I wanted to add something more to them and I was inspired by the amazing modelling work of this guy http://www.militarymodelling.com/news/article/make-it-real-part-1/4083
    Chapel
    First I pushed a stone into the stone work to rough it up and create some unevenness to it. Then I added some random pieces of wire and card to the building, which I saw a lot of in the link above. I reduced the sizes of the stones supports and they look much better now. Also I’ve seen pictures of stone buildings which have metal plate and bolts which is maybe some sort of bracing. Finally I gave the building a thin watered down wash of polyfilla mixed with caulk over the stone work and wiped off any excess. it also help fill the gaps.
    Barn
    I followed a similar process to the chapel and glued some random pieces onto the building. Included was a sign from an Italeri set and a ladder I think from a Hasegawa watchtower. The metal plates were card and I used some cut off brass pins for the bolts (which I forgot on the chapel). And a couple of pieces if plasticard I add above the main barn doors.
    Next up, basing and painting
    • This reply was modified 2 months, 2 weeks ago by 6mmwargaming 6mmwargaming.
    #75445
    William Harley
    William Harley
    An excellent model, thanks for sharing.
    #75451
    Noel
    Noel
    That’s inspiring.
    #76112
    6mmwargaming
    6mmwargaming
    Lots of progress in this update as i forgot to take photos during the painting stages!
    For the brick walls I wanted to try a new and hopefully more realistic technique. I painted the buildings with a slate colour and then once that was dry I went over the wall with a white paint. While the white paint was still wet, I wiped it off the highlights with a tissue,leaving the white in the cracks (to look like mortar). Some pieces I had to go over a couple of times and on some places the tissue removed some of the slate base colour. This actually helped with the effect, giving the bricks some shading and variation.
    Next I washed parts of the wall with brown and green washes and then followed up with some green and brown weathering powders. Rust powders were used on the metal parts on the buildings.
    Originally I wasn’t going to base the buildings but I decided to go with a simple and small basing scheme. For the church I kept it basic with a small base and a ruined piece of wall. Later on I will add some gates and a couple of gravestones. For the barn I added a wall made from foamboard, cardboard and a some Busch gate posts. Parts of the Barn base is blended into the building at the back so that the base is not to intrusive.
    Thanks for looking
    #76114
    Guy Farrish
    Guy Farrish
    Thanks for posting!
    They turned out beautifully – lovely bit of work.
    #76119
    6mmwargaming
    6mmwargaming
    Thanks
    Still not quite finished but close!
    #76123
    Very cool, just went and had a reminisce over the 6mm Greek build.
    So nice.
    #76181
    6mmwargaming
    6mmwargaming
    So nice.
    yeah some of my best work. Back to 6mm soon….
    #76239
    Autodidact-O-Saurus
    Autodidact-O-Saurus
    These look really great! Thanks for sharing your techniques.
    #76241
    Tim
    Tim
    Very cool, just went and had a reminisce over the 6mm Greek build. So nice.
    Nope.  You are hereby ordered to stick to 1/72 on account of the great results here.
    #76971
    6mmwargaming
    6mmwargaming
    Thanks
    Progress has taken a turn on this with the start of some new roofs!
    I’m using smaller tiles and trying to make the more regular. I plan to paint the roofs brown (like in the photo at the top of this thread). This is very time consuming cutting and gluing the tiles but hopefully they will be finished in a day or so
    Also I painted up some accessories for the buildings
    #77872
    6mmwargaming
    6mmwargaming
    I’ve slowed down a bit on this as it is summer here in NZ and actually nice and hot!
    The roofs are finished and it took longer than hoped to cut up all the tiles!
    You can also see the basing is done but more on that later.
    I changed the style of the barn roof so it fits inside the stone walls now. There is still some work to do, to make it fit well
    Onto the final steps of painting the roof and fixing up the barn a little.
    #77873
    Duuuuuuuuude.
    #77874
    Rhys Humphrey
    Rhys Humphrey
    You have immense skills – thanks for sharing and showing us how its done!
    http://thegreatspaceopera.wordpress.com/
    #77990
    6mmwargaming
    6mmwargaming
    Thanks, I like to post my own progress as I find it helps me. As you can see I tend to wing it which means I alter the design as I go.
    #77999
    Patrice
    Patrice
    Very interesting! Thank you.
    http://argad.forumculture.net/
    #78276
    6mmwargaming
    6mmwargaming
    Hi all
    The chapel is completed with a new roof and the basing done. I’m very pleased with the new roof and it looks much more like the photo of the actual chapel I based it on.
    I painted the roof various craft paint browns and gave it repeated drybrushes (perhaps too heavy but it stands out), and then glued some Woodlands Scenics burnt grass onto the roof to represent moss
    The base was 3mm mdf and I added a couple of Renedra cross and one made from sprue. The broken wall is made from foamboard with the gate and railings from Gamecraft, and the post from a model railway shop.
    More soon on the barn
    • This reply was modified 1 month, 1 week ago by 6mmwargaming 6mmwargaming.
    #78538
    6mmwargaming
    6mmwargaming
    And here’s the finished Barn. With a gate from one of the model railway wall sets (it is actually a iron wall section).
    With a finger for scale!
    And it looks like I forgot to add something like a decal to the sign
    I hope you enjoyed the thread. I have some old Airfix buildings to pimp next
    #78544
    So much win.
    The attention to detail not only in the making but the painting too.
    kudos.
    #78546
    Rhys Humphrey
    Rhys Humphrey
    Awesome work!
    #78553
    Tim
    Tim
    Wow.
    #78554
    Darkest Star Games
    Darkest Star Games
    Those are some great pieces!  I really like the weathering, realistic yet not over done.  And, as a guy that does architecture and sees a lot of models, I’d just like to say that your attention to the innocuous little details, such as the surface mounted electrical conduits, is both awesome and appreciated!
    #78572
    6mmwargaming
    6mmwargaming
    Thanks guys.
    I really wanted to improve my work and I noticed a lot of wargames building don’t have the extra little details. The link I posted earlier really made me think about those.
