Home Forums Terrain and Scenery 1/2400 naval terrain
  • #6890
    Avatar photoShandy
    Hi!
    I’ve started a small 1/2400 napoleonic naval project and would like to build some terrain – mainly a piece of coast to play amphibious operations. I guess I can scratch build a coastline, but buildings might be more difficult.  Those have to be very small… I might try also building them from scratch, but are there any available commercially? I’ve heard that some people use the Irregular Miniatures 2mm buildings, but scale wise they are quite off – do you know how they look with 1/2400 ships?
    I’d be grateful for any hint!
    Thomas
    #6892
    Avatar photoNorthern Monkey
    Langton miniatures do a whole range of port like buildings, harbour pieces, fortifications, dockside accessories etc, I have quite a few and they’re really nice and reasonably priced
    EDIT: actually they are 1200th scale so might not be suitable however, if youre prepared to use 2mm stuff then you may want to look at the Langton stuff too
    My attempt at a Blog: http://ablogofwar.blogspot.co.uk/
    #6895
    Avatar photoShandy
    Thanks, I’ve seen the Langton buildings on their web site but assumed that they would be too large for 1/2400 – what do you think? Are they reduced in size for 1/1200?
    #6901
    TBh im not sure how they would look,  in the following very quickly taken photos the white house on the dockside is about 6mm up to its eaves and the doorway is about 2.5mm if that’s any help:
    #6902
    Actually now that I compare them to my 1/3000th (albeit WW2) ships the smaller buildings don’t look too bad, and I imagine would look better with 1/2400 stuff, but the larger buildings are well off.
    #6961
    Avatar photoShandy
    Thanks a lot for the images! Hm, I might try the smaller ones… but first, I’ll probably give scratch building a try…
    Nice paint job btw!
    #7930
    Avatar photo6mmwargaming
    Try also Navwar or Heroics and Ros. They have a range of 1/3000th terrain to go with their naval range (not sure who owns it now).
    Cheers
    Kieran
    #8100
    Avatar photoShandy
    Thanks for the hint Kieran, I didn’t know about the Navar buildings – seems they have at least some for the age of sail.
