Home Forums Air and Sea Naval A couple of painted trawlers
This topic contains 4 replies, has 3 voices, and was last updated by Brian Weathersby Brian Weathersby 4 months, 2 weeks ago.
  • #105147
    Brian Weathersby
    Brian Weathersby
    In the Cod Wars post on my blog, several people wondered how the clear ships from Shapeways would look once they were painted up.  So, I’ve put together a quick post showing off two of the trawlers that I’ve finished.  Please drop by and check them out:
    https://mymodelsailingships.blogspot.com
    • This topic was modified 4 months, 2 weeks ago by Brian Weathersby Brian Weathersby. Reason: spelling correction
    I'm lucky to be here
    With someone I like
    Who maketh my spirit to shine
    --Warren Zevon
    #105153
    Thomaston
    Cool, I like the rust effect you did.
    #105165
    Brian Weathersby
    Brian Weathersby
    Thanks.  I took a terracotta color and an earth brown, mixed them together and then thinned it way down.
    With someone I like
    --Warren Zevon
    #105188
    zippyfusenet
    Interesting article and excellent results. Thanks.
    You strongly recommend priming the Shapeways ships, and not just using any dark paint for a basecoat. What primer do you recommend? And why is priming necessary?
    #105219
    Brian Weathersby
    Brian Weathersby
    Normally I just use any rattlecan primer, usually in black.  What happened here is that I picked up a can of satin black by mistake.  It left the model very slick, and my normal paints just wouldn’t grip the model.  So, I decided to spray the ship with a clear flat to give my paints something to hold onto.  What happened instead was the the black paint crackled like an old piece of furniture.  I was afraid of trying to clean off the paint with something like acetone because I didn’t know what it would do to the model.
    As to why I primed, well the recommendation on the Shapeways forums is that you do so.  An interesting point came from the designer of the minis; he told me on my blog that there is something in the clear plastic material that stops enamel paints from drying unless the model is “extremely clean.”  I did clean them with Simple Green and Dawn detergent as recommended,  but maybe I didn’t get it clean enough for the enamel spray paint to dry?  I don’t know enough about chemistry to say why a “primer” is better than regular paint, but it does appear to be the case on these.
    With someone I like
    --Warren Zevon
