Home Forums General General Best Way to Strip Paint from Figs with Plastic Parts?
  • #11886
    Avatar photoirishserb
    I need to strip paint from  some old figs that I bought some time back.   The figs are metal, but have some plastic parts, what will strip the paint from the plastic parts without attacking the plastic?
    Thanks,
    irishserb
    #11896
    Avatar photoPijlie
    Use Dettol, a generally available desinfectant. It will solve most paints and leave the plastic (and the metal) untouched.
    http://pijlieblog.blogspot.nl
    #11903
    Avatar photowillz
    As “Pijlie” says Dettol works brilliantly, leave them soaking for a few days and wipe the gunk off with a cloth or tissue and then I wash in soapy water, then rinse under a hot tap, finally wire brush them clean.  (added bonus your figures are 99% germ free.)
    Only discovered Dettol  as a paint stripper 2 years ago.
    #11914
    Dettol is great. You cna also use Simple green if you can get it – Does the exact same thing.
    #11953
    Thanks all.  I was able to find Simple green locally, and will give that a try, though I think I will order some Dettol from Amazon.
    Thanks again.
