Home › Forums › Horse and Musket › Napoleonic › Buildings for 18mm?
- This topic has 11 replies, 7 voices, and was last updated 3 years, 6 months ago by grizzlymc.
28/08/2020 at 14:54 #143055Philip ClareParticipant
Just acquired some 18mm Napoleonics from Wofun Games. The figures fit on 3x2cm bases and I’ve got a Tiny Wargames mat with hexes on that will hold 1 base at a time.
I’ve been thinking about buildings. Any suggestions welcome on a manafacturer and should I go for models that ‘represent’ a farm or plan on using buildings that cover a realistic amount of ground. I’m thinking the latter will be quite large?
Grateful for any advice – new to this.
28/08/2020 at 19:09 #143067kyoteblueParticipantI would use 20mm buildings, but they may look too big depending on the ground scale of the rules you use.
28/08/2020 at 22:46 #143077vtsaogamesParticipantFor my 15mm figures, my favorites are 10mm buildings from Paper Terrain. Each buidling comes with a ruined version that fits inside. Lift off the intact one after a number of turns of combat. Or have twice as many buildings, some wrecked.
29/08/2020 at 08:22 #143081Alan MillicheapParticipantFor 1-1 skirmish level games I use same-scale buildings
For everything else I use buildings that are 1 size smaller ie for 10mm games I use 6mm buildings
30/08/2020 at 09:14 #143131MartinRParticipantI use 6mm buildings with my 15mm stuff. Timecast, Hovels or home made.
Sub scale is just more in keeping with the ground scale, unless you are doing skirmish where the figure and ground scale are the same.
30/08/2020 at 10:06 #143135willzParticipantHere are some photo’s of WOFUN 18mm WSS with 1/87, HO model railway buildings. They work if you call a house a small village.
An old Airfix building.
30/08/2020 at 10:15 #143137willzParticipantI am not sure about the size, I use these buildings for my 28mm armies but not sure I may have to build some 12 – 15mm scale buildings or try some is it N gauge railway buildings that’s 1/150th I think.
Found these
Also there is a N gauge firm called Kibri
30/08/2020 at 15:41 #143151willzParticipantWhilst net surfing found these.
31/08/2020 at 10:34 #143198Philip ClareParticipantMany thanks for all the replies and links. I’ll go for the ‘down-a-scale’ approach to get villages etc represented on the table.
31/08/2020 at 13:05 #143223willzParticipantI am of the same thought Philip, going into town tomorrow to my local railway model shop to see what N gauge second hand buildings they have.
03/09/2020 at 13:34 #143441willzParticipantHere are some photo’s of the building I am using for my Wofun 18mm figures, (I know they are not Napoleonic). I was going to buy some N gauge building but at £12 starting price, I got Peter Dennis castle assault for £6 so scanned the houses and shrunk 50% and printed on thin card.
03/09/2020 at 13:55 #143442grizzlymcParticipantThat Airfix building is a classic. Takes you from pointy sticks to the near future.
