- This topic has 2 replies, 2 voices, and was last updated 7 years, 11 months ago by .
I want to use 28mm within a small space (4′ x 3′) and Basic Impetus is grabbing my interest.
It seems sensible to try and reduce the base frontage down from 12cm, but I think the 8cm frontage for 15mm is probably a tad too tight.
I have some Perry Wars of Roses cavalry and they look like a nice base could be made at 4 figures wide on a base at 10cm wide and probably 9 or 10 cm deep to get 6 or 7 knights on it.
For those that play the game, can anyone see a reason (other than I have to provide both armies) why that would not work?
thanks in advance.
It will work, just about anything will work as long as you fiddle appropriately with the measuring “unit “value. Frontage is always the guide for subsequent measurement in any good set of rules so other than the U value I dont see a problem. There are a couple of very good facebook pages for Imeptus so if you run into problems they will help you out in a flash. Look forwards to seeing some AAR’s
https://www.facebook.com/groups/420092258116857/
https://www.facebook.com/groups/impetvs/
Slowly Over A Low Flame
Thanks, I have worked up some empty bases using the measurements given for 15mm scale and will be pushing those around this weekend. I did think of going from 12cm to 10cm (rather than 8cm), but the saving of just 2cm per base does not seem to justify doing something that is out of kilter with recognised sizes.
