- This topic has 13 replies, 3 voices, and was last updated 2 years, 6 months ago by Robert Dunlop.
27/09/2021 at 21:23 #162334Robert DunlopParticipant
It seems better to start a new thread on this topic, rather than append something to the existing threads on WW1 late war French and German miniatures. For anyone not familiar with the Crossfire rules, check out this website:
https://crossfire.wargaming.info
There are several videos featuring Crossfire on YouTube too.
From a rules perspective, there is very little needs changing. Given the lack of defined ground scale, no adjustments are needed to account for the greater density and narrower frontages on the Western Front compared with WW2. If you haven’t already done so then do check out Steven’s house rules on operational zones:
The concept is very applicable to WW1, avoiding any tendency to suddenly withdraw and reorient a unit from one side of the table to another, based on the movement rules associated with an Initiative.
With regards to rifle grenadiers (RG):
1. RG squad stand operates on-table and can move as per Rifle Squad stand
2. RG stand can function as normal Rifle Squad OR as 60mm Mortar stand on any given firing
– Must have Line of Sight to target but can fire over friendly troops;
– Attack Dice 3; No Kill Potential OR Call-In a 2 infantry stands long smoke screen
– Maximum 12 Fire MissionsCrossfire doesn’t separate out LMGs, so I would recommend the same approach for WW1 too.
For vehicles, we have a useful starting point in the existing Crossfire ruleset:
WEAPON: RENAULT FT
ARM: 1/1
ACC: -2
PEN: -2
HE/EFF: 2/1 SQ
The example above is for the version armed ‘with cannon’, which was the 37 mm gun. Based on other examples in the Data Sheet, the machine gun armed version of the Renault FT would be:WEAPON: RENAULT FT
ARM: 1/1
ACC: –
PEN: MACHINE GUN
HE/EFF: 4/1 SQThe Renault was the only tank with a turret in WW1 but it is marked as “No” for the “Hull Down” (HD) option. No other vehicles should get HD status in WW1.
Using these stats as a starting point, we can then build in the other tanks, armoured cars and equivalent. Incidentally, the stats give us a starting point for the 37 mm infantry and anti-tank guns used by the French, Germans and Austro-Hungarians.
More to come…
Robert
27/09/2021 at 21:28 #162335Robert DunlopParticipantAnother weapon system that we can lift directly from the Data Sheet is the German AT rifle. The T-Gewehr was not the same as the German WW2 AT rifles but the differences are not really significant IMHO. This means we can go with the following stats:
WEAPON: ANTI-TANK RIFLE
ARM: –
ACC: -2
PEN: -4
HE/EFF: 0 SQRobert
28/09/2021 at 08:13 #162349MartinRParticipantI treat rifle grenadier sections as normal rifle sections but they ignore the cover penalty for open topped cover.
CF works really well for WW1, the later period anyway.
28/09/2021 at 11:25 #162351Robert DunlopParticipantThanks, MartinR.
There are two other weapons that transfer directly from the Data Sheet, such as the French 75mm field artillery gun that was also used by the American Expeditionary Force:
WEAPON: IG 75 MM
ARM: –
ACC: -2
PEN: -2
HE/EFF: 4/2 SQThe Russian 76mm infantry gun (not the high velocity anti-tank gun), which was used by the Germans as well in WW1, has the same stats as the French 75mm.These stats are the same for the WW2 German 76mm infantry gun as well. Based on the alignment across the three WW2 infantry guns in the Data Sheet then I recommend that the same stats are used for the following in WW1:
Russian Putilov 3″ field gun
German 3″ infantry gun, based on captured Russia field guns
German 75mm and 77mm field guns (75mm used by Ottomans for example)
French 75mm field gun (used by Americans)
British 18 pounder field gunThe German light Minenwerfer can have the same stats for its use in direct fire mode as an anti-tank gun. The indirect fire capability cross-links with the mortars rules, so I will deal with this aspect separately.
Robert
28/09/2021 at 12:42 #162354Robert DunlopParticipantThe British Whippet Medium A tank had roughly the same armour thickness as the Renault FT. It carried up to 4 Hotchkiss machine guns but, in practice, could only fire one at a time due to only having one gunner in the cramped crew compartment. So the stats are the same as the Renault:
WEAPON: WHIPPET MEDIUM A
ARM: 1/1
ACC: –
PEN: MACHINE GUN
HE/EFF: 4/1 SQRobert
28/09/2021 at 14:09 #162355JozisTinManParticipantAll looks great! I will be trying these in the next few weeks
28/09/2021 at 18:23 #162367Robert DunlopParticipantThe A7V was a very interesting, and much underrated, tank from WW1. There are several aspects that are important from a Crossfire perspective. Although the side armour thickness was roughly that of the Renault FT, the front armour was 50% thicker again. Almost all A7Vs had a front-mounted 57mm gun. This was a low velocity weapon, similar to that used in the British Mk Male tanks. The stats for the A7V main gun will, therefore, work for the British 57mm too. The only exception was A7V ‘Gretchen’, which went into its first battle with two front-facing MGs, in addition to the 6 MGs that were standard on all A7Vs – 2 each on either side, and 2 facing to the rear. Unlike the Whippet, each MG had its own crewman/gunner.
Going back to the Crossfire Data Sheet, the equivalent WW2 tank in terms of a low velocity 57mm gun is the Japanese Type 89. Its ARM stats reflect the stronger front armour of the A7V too, giving us something like this:
WEAPON: A7V
ARM: 2/1
ACC: -1
PEN: -1
HE/EFF: 2/1 SQThe A7V (as well as the Schneider, St Chamond and British Male heavy tanks) had a Main Gun and multiple MGs. This is where the Advanced Rules 2. comes into play (p. 44). I have copied the original text and made some changes to reflect the A7V :
– The vehicle must remain stationary the entire Initiative to fire either the Gun or [one or more] MG[s].
– The vehicle may fire both the Main Gun and the MG[s] in a single action, and may do so as a Firegroup. [In practice, this was unlikely to happen because of the 45 degree arcs of fire preventing the Main Gun from having the same target as any of the MGs but in a British male heavy tank, each main gun and an MG would have overlapping arcs of fire. The A7V MGs on one side of the tank could participate in a Firegroup.]
– OR the Main Gun may fire at one target and the MG[s] at [other targets].
– If the Main Gun does not produce a Kill or a Suppression, the Initiative shifts.
– Firing the MG[s] with the Main Gun does not entail a loss of Initiative if it misses.
– If only the MG[s] fire[s] in an Action (and not the Main Gun also), Initiative is lost if the MG[s] fail[s] to Suppress the target. If it does Suppress the target, it is entitled to fire again.There are two other important features of the A7V to consider. First is the ability to dismount the equivalent of MG stands if the vehicle is destroyed. This capability was similar to the Schneider, St Chamond, and British heavy tanks. It is akin to the rules on APCs in Crossfire, as per Sections 11.1.2 and 11.2.1. Specifically for the A7V, I would recommend that an A7V can dismount 3 MG stands if destroyed, subject to:
– Receiving a number of Kills to the MG stands equal to the EFF of the gun that destroyed the tank; and
– Any remaining MG Stands are Suppressed on the spot.The second feature is that the A7V had enough room to carry the equivalent of two Squads in addition to its normal crew complement. In essence, the A7V was able to operate as an APC as well as a tank. If a player chooses this option then the two extra Stands can be dismounted as one step per Initiative (but cannot Mount again), within one stand of the A7V.
The British MkV* also operated as a combined APC/tank, so the second feature of the A7V would apply to the MkV* as well except that the stands would be MG stands.
Robert
28/09/2021 at 18:32 #162368Robert DunlopParticipantNow to the British MkIV and MkV heavy tanks. Armour-wise, I don’t think there was much improvement between the two versions. The MkV tanks were slightly faster, had better steering, and better reliability. None of these advantages really count on a WW1 Crossfire battlefield IMHO. The female variants were armed with a forward-firing LMG and two LMGs on either side.The armour wasn’t much thicker than a Renault FT17. This suggests both female versions are:
WEAPON: MkIV FEMALE
ARM: 1/1
ACC: –
PEN: MACHINE GUN
HE/EFF: 4/1 SQWEAPON: MkV FEMALE
ARM: 1/1
ACC: –
PEN: MACHINE GUN
HE/EFF: 4/1 SQThe male versions had one forward-firing LMG and one LMG on each side, plus a 57mm low velocity Main Gun on each side. For the two Main Guns, the stats for each one will be:
WEAPON: MkIV and MkV MALE
ARM: 1/1
ACC: -2
PEN: -2
HE/EFF: 2/1 SQThese tanks are the one case where I would treat each LMG as an MG, which can fire with the Main Gun on the same side or fire independently from the Main Gun as per A7V.
Two MG stands can dismount from a destroyed tank, subject to the Kill and Suppressed rules for the A7V and MkV* crews.
The MkIV and standard MkV tanks did not carry extra stands.
Robert
28/09/2021 at 18:34 #162370Robert DunlopParticipantThe captured British MkIV Beutepanzers were typically female variants, as these were more common and therefore more likely to be captured but also there was a shortage of the 57mm gun, which was given priority for use in the A7Vs. Beutepanzers had a forward-firing MG and two MGs on either side. Some had a forward-firing T-Gewehr anti-tank rifle. This suggests the following:
WEAPON: MkIV FEMALE BEUTEPANZER
ARM: 1/1
ACC: –
PEN: MACHINE GUN
HE/EFF: 4/1 SQWEAPON: MkIV FEMALE BEUTEPANZER WITH ATR
ARM: 1/1
ACC: -2
PEN: -4
HE/EFF: 0 SQIn the Beutepanzer armed with an ATR, the MGs can also fire independently of the ATR.
Robert
28/09/2021 at 19:15 #162372Robert DunlopParticipantArmoured cars next. There are six types for starters but the basic principles can easily be applied to any others. The armour was not significantly better than the Renault FT17. The six, with variants, are:
WEAPON: AUSTIN AC; PEUGEOT AC (MG); WHITE AC (MG); MINERVA AC; ROLLS ROYCE AC; LANCHESTER AC
ARM: 1/1
ACC: –
PEN: MACHINE GUN
HE/EFF: 4/1 SQWEAPON: PEUGEOT AC (37MM); WHITE AC (37MM)
ARM: 1/1
ACC: -2
PEN: -2
HE/EFF: 2/1 SQThe Austin had two MGs in independently rotating turrets. Peugeot had either a single MG or a 37mm Main Gun but not both. The White armoured car had a 37mm Main Gun and an MG, facing in opposite directions. Minerva had either one or, sometimes, two MGs. Rolls Royce and Lanchester armoured cars both had a single MG.
Robert
28/09/2021 at 19:16 #162373Robert DunlopParticipantThe Borden MG Autocar is pretty straightforward too. It had two MGs that could be aimed independently.
WEAPON: BORDEN MG AUTOCAR
ARM: 1/1
ACC: –
PEN: MACHINE GUN
29/09/2021 at 05:25 #162377Robert DunlopParticipantNow for the French medium tanks, which are a little bit more tricky because of their Main Guns. The Renault FT17 has already been covered off previously, having stats defined the Crossfire Data Sheet. The later versions of the Schneider (such as supported the Big Red One [US First Division] in the assault on Cantigny) and St Chamond carried spaced armour to provide more protection. The front ends of both tanks had sloped armour too. It is hard to gauge, however, the degree of armour protection from a Crossfire perspective but it could be reasonable to argue for something akin to the T-26 rather than the FT17.
The Schneider had two MGs, one on either side, plus a short barrel low velocity 75mm Main Gun. The latter could be regarded as equivalent to the Main Gun on the Panzer IVD.
The St Chamond had 4 MGs and a forward-firing high velocity 75mm Main Gun, basically the French IG 75/MM in the Crossfire Data Sheet. It operated in an assault gun mode, able to engage German anti-tank guns at distance for example. This is less important, however, from a Crossfire perspective. St Chamonds supported the AEF in some engagements such as the assault on Montfaucon during the Battle of the Meuse-Argonne.
Based on the above, here are the proposed tables:
WEAPON: SCHNEIDER; ST CHAMOND
ARM: 2/1
ACC: -1
PEN: -2
HE/EFF: 4/2 SQThe first versions of the Schneider and St Chamond would be ARM 1/1.
Robert
29/09/2021 at 05:29 #162378Robert DunlopParticipantMortars next. There were three main types of mortar from a Crossfire perspective, though many more were used at various times. To keep it simple and to match the Battlefront Great War offerings, the main types were: Stokes mortar (British, French and US); French 58mm Type 2 (nicknamed ‘Crapouillot’); and the German rifled leichte Minenwerfer (lMW), which fired a 76mm projectile. Later versions of the lMW were able to fire directly as an anti-tank weapon:
Here are some stats; first the German light Minenwerfer used in direct fire mode:
WEAPON: LIGHT MINENWERFER [Direct fire mode]
ARM: –
ACC: -2
PEN: -2
HE/EFF: 4/2 SQThe Stokes mortar and light Minenwerfer used in indirect fire mode are classified as Mortars & Guns to 82mm/ 3″ Mortar, which have 4 Attack Dice and a Kill Potential of 1 Squad.
The Crapouillot could fire a bomb with 10 kg of explosive, twice the weight of a Stokes mortar bomb. This would put it in the Guns 85mm+ /Mortars to 120mm/ 4.2″ category, with 4 Attack Dice and a Kill Potential of 2 Squads.
There was a 4″ calibre Stokes mortar, used by the British and the Americans. It could fire a 4 infantry stands long Smoke Screen. It was not used to fire HE bombs but could fire gas and thermite bombs, neither of which are relevant to Crossfire IMHO.
Robert
29/09/2021 at 05:35 #162379Robert DunlopParticipantA 37mm infantry gun was used by the French, Americans, and the Austro-Hungarians. The French/US version was manufactured by the same company, Puteaux, that made the Main Gun for the Renault FT17 but had a lower muzzle velocity (about 50% less). Here is my suggestion, based on the Type 95 37mm used on the Japanese light tank:
WEAPON: 37MM IG/ATG
ARM: –
ACC: -1
PEN: -3
HE/EFF: 1/1 SQThese stats will work for the German 37mm anti-tank gun too.
The Granatwerfer fired HE and smoke. It is equivalent to the 50-60mm Mortars, 2″ Mortar category, with 3 Attack Dice and no Kill Potential. The smoke round will be two stand-widths long.
Flammenwerfer teams operate as Assault Engineers, getting the +1 bonus in Close Combat.
Robert
