Home › Forums › Air and Sea › Air › Hexless WW2 Air Combat Rules
- This topic has 7 replies, 5 voices, and was last updated 6 years, 6 months ago by 6mmwargaming.
15/10/2017 at 13:18 #73935Jim JackamanParticipant
I’m thinking of doing an Eastern Front WW2 project in 1/144th scale using zvezda and revell plastic kits.
Any suggestions for hex less air combat rules?
Thanks
Jim
15/10/2017 at 15:47 #73954WhirlwindParticipantLacquered Coffins: http://www.wargamevault.com/product/205740/Lacquered-Coffins-WW2-Air-Combat
Wings of Fire: https://boardgamegeek.com/boardgame/32231/wings-fire
Air Battles in Miniature: https://www.amazon.co.uk/Air-Battles-Miniature-War-gamers-1978-05-17/dp/B01FKWZ1OC/ref=sr_1_fkmr0_2?s=digital-text&ie=UTF8&qid=1508078805&sr=8-2-fkmr0&keywords=air+battles+in+miniature+mike+stick
15/10/2017 at 21:20 #73989Don GlewweParticipantAny suggestions for hex less air combat rules?
TBH, that doesn’t strike me as a meaningful distinction. Hex movement has little to nothing to do with how a ruleset addresses aircombat.
An objective/goal is, imo, more important. So: What sort of game do you want to play?
16/10/2017 at 20:12 #74089Jim JackamanParticipantI play a lot of hex based games but I’m looking for a set of rules that I can use on a terrain cloth without hexes, just for ease of set up and simplicity.
It would be for small low level dogfight scenarios with perhaps half a dozen aircraft a side or thereabouts.
Typical Eastern Front ground attack, reconnaissance, dive bombing, fighter vs fighter stuff, that sort of thing.
Simple enough for beginners to pick up and play.
I was thinking of Sturmovik Commander, or perhaps adapting the Wings AT War system from 1/600 to 1/144?
:O)
16/10/2017 at 20:13 #74090Jim JackamanParticipantLaquered Coffins looks interesting but I’m not a fan of IGOUGO.
17/10/2017 at 12:30 #74117NKL AerotomParticipantHey Jim – would you be interested if the best quality pilots went first? This is the way we play Lacquered coffins these days (and at some stage I will write an update incorporating this)
Essentially all mandatory moves are done simultaneously, then aircraft activate in order, with the best quality pilots going first. If both sides have pilots of the same quality, they roll off each turn to see whose side gets to go first.
IGOUGO does work very well for much larger games – keeps things simple when there are 40+ aircraft on the table 🙂
For smaller games we’ve found the quality-based activation works quite well without any other changes.
Tom Jensen - http://ostfrontpublishing.com/
17/10/2017 at 18:17 #74159Jim JackamanParticipantYes that would work for me. It’s similar to some other games I’ve played and would work well for what I’m thinking of.
Thanks for the idea.
:O)
Jim
21/10/2017 at 23:14 #745036mmwargamingParticipantAlso have a look at Scramble by A & A Games. it is initiative based by plane (or you could by flight which we do). Pilot quality is also important to initiative, maneuvering and shooting.
I’ve got some old battle reports here (near the bottom). Excuse the web page formating!
