Home › Forums › Terrain and Scenery › Junk build scifi skirmish scenery for Stargrave, Planet 28 and others
- This topic has 128 replies, 18 voices, and was last updated 13 hours, 23 minutes ago by
6mmwargaming.
23/10/2021 at 06:10 #163650
6mmwargaming
ParticipantHi all
I’ve started a new project to build enough 28mm scifi scenery for a densely populated 4×4 table. I have been collecting household junk, various 40K and other model bitz, 3D printed parts as well as some scifi pieces from a Dungeons and Lasers kickstarter. There’s no real plan apart from meeting some of the Stargrave and Planet 28 scenario requirements.
To start I begun with some generic scifi scatter pieces which I completed a while ago but I’ll start with the WIP pictures.
The building on the left was made with a couple of kinder eggs, lots of random bits and the base is PVC foam, the middle building is made from some plumbing pipe with a 3D printed vent on top and door. the bigger building si made from a christmas decoration ball, pvc foam supports and acables from green stuff and recycled 3D printer fans.
The green cables are made using a “Green stuff tentacle/cable roller” which I 3d printed and its the first time I tried it out. I’m very pleased with the results and I will covering all my building in cables from now on.
My site https://wargaming.info/6mm/
23/10/2021 at 08:42 #163651Mike
KeymasterBrillliat stuff as to be expected!
LOLOL
23/10/2021 at 17:18 #163687Jim Webster
ParticipantLooking good, some nice ideas
23/10/2021 at 21:43 #163699Cacique Caribe
ParticipantFantastic, well done!
Dan
Loads of WIPs: https://www.flickr.com/photos/[email protected]/albums/with/7215771063052937624/10/2021 at 14:55 #163726Fred B
ParticipantReally liking those – especially the kinder egg “silos!” The cables really add to those pieces – might have to print some of those cable/pipe makers myself.
24/10/2021 at 19:21 #1637316mmwargaming
ParticipantThanks everyone
Here the next couple of pieces, I’m not really sure what they are, perhaps a small power generator and a cooling unit.
They are mostly made from XPS foam with Dungeons and Laser parts, and some sprues. I also used some worn out 3D printer bearings!
24/10/2021 at 20:04 #163734willz
ParticipantVery nice models.
25/10/2021 at 18:49 #1637926mmwargaming
ParticipantThe first two buildings are finished. After messing up the numbers a few times I’m calling them done and ignoring a few remaining mistakes on the painting. I went for a pretty basic colour schemes partly because I didn’t have many colours for my airbrush. The numbers were done with a 3d stencil I printed out.
I think I will try a different font as these aren’t very scifi, but otherwise I’m very pleased with the results.
26/10/2021 at 01:02 #163803Thomaston
ParticipantMan, these are great builds.
I like tiny miniatures27/10/2021 at 07:47 #1638666mmwargaming
ParticipantThe next two pieces are finished are
I’m very pleased with how these came out.
27/10/2021 at 09:45 #163870Mike
Keymaster27/10/2021 at 09:49 #163871Mike
KeymasterI think I will try a different font as these aren’t very scifi, but otherwise I’m very pleased with the results.
Neuropol FTW!!
27/10/2021 at 09:55 #1638726mmwargaming
ParticipantGreat stone/concrete texture. foam?
Yes all XPS foam except the base of the greenish piece, which is made from Foamed PVC. I pushed a piece of scoria rock into the foam to create a rougher texture. I used a piece of foam and dabbed the paint on to create a concrete effect.
27/10/2021 at 11:29 #163874Thuseld
ParticipantThese look awesome. 28mm terrain building always feels so daunting to me, but maybe with small things like this, it is possible. For Five Parsecs level games. I love your talent at putting bits of junk together to make great looking terrain.
Experiments here: http://inexperiencedmodelmaker.blogspot.co.uk/
Tranquil Stars updates: https://tranquilstars.wordpress.com
27/10/2021 at 11:46 #1638766mmwargaming
Thanks. Its mostly gluing random junk onto a pieces of foam or other random junk. I have a folder of pictures of other peoples terrain I use for inspiration along with some websites, especially these
https://miniatureextravaganza.blogspot.com/
https://oldschoolworkshop.blogspot.com/
http://port-imperiale.blogspot.com/
30/10/2021 at 02:17 #1640076mmwargaming
ParticipantHere’s the next few pieces of scenery which were pretty quick to make.
3D printed wheels with a Dungeons and lasers crate. The middle piece is another Dungeons and Lasers piece and the $2 shop christmas baublescame in very handy as domes.
The larger industrial piece is useful as table filler and has the obligatory computer fan and lots of cables. also more D and L parts, 3D printed parts and the mesh panels are from a Conflix Cyberclicks set. I like this piece and the simplicity design of it and it was heavily inspired by some of the 40k scenery here http://miniatureextravaganza.blogspot.com/
30/10/2021 at 03:24 #164010Andrew Beasley
ParticipantIs that a green stuff cable on the roof?
I’ve handled the results of the rollers for bricks etc but often wondered how strong the cables are. The narrow bits looked very thin in the videos I’ve watched and I wonder if they snap…
30/10/2021 at 03:32 #1640116mmwargaming
ParticipantIs that a green stuff cable on the roof? I’ve handled the results of the rollers for bricks etc but often wondered how strong the cables are. The narrow bits looked very thin in the videos I’ve watched and I wonder if they snap…
Yes they are pretty thin. I saw a good video on how to avoid this by wrapping it around a piece of wire (I used copper). It also means you can bend the pieces once the green stuff has hardened and it works really well. See here
30/10/2021 at 20:19 #164032Andrew Beasley
Participant..
…Obvious now you mention it but that would never have crossed my mind despite using wire for plain cables!! Thanks for sharing that
01/11/2021 at 06:36 #1640746mmwargaming
ParticipantAll the scatter terrain finished!
I’ve started on some habitats and hopefully I’ll post them next
04/11/2021 at 07:32 #1642086mmwargaming
ParticipantNext up are some high tech habitats. I’m also planning some shanty style buildings so I wanted these to look a bit cleaner and better quality living!
The main plastic shape for the house is recycled from a 1/72nd diecast model tank, which I glued a bunch of bits on. The cables are made from green stuff along with pieces of electrical wire, and the doors and shutters are 3D printed. The lights and security cameras are from the Dungeons and Lasers range and are pretty cool.
Also I finished a Garage/workshop. I think the main shape was from the packaging for some headphones. As per the other building, I glued some mostly 3D printed parts on as well as other Christmas decoration ball. The white pieces strips are made from PVC foam.
Thanks for looking
04/11/2021 at 07:40 #164209gamegonegood
Participanta great set
04/11/2021 at 13:29 #164231Darkest Star Games
ParticipantDarn cool looking. Looks like these habs are in a rough part of the galaxy!
04/11/2021 at 14:56 #164235Cacique Caribe
ParticipantFantastic ideas!
Dan
Loads of WIPs: https://www.flickr.com/photos/[email protected]/albums/with/7215771063052937604/11/2021 at 22:17 #1642456mmwargaming
ParticipantThanks, I like how they have come out. I started painting them and went for a sandstone finish but that was a disaster, so I am stripping back to the raw plastic! I prefer the clean look for these as some of the other buildings I’m planning are going to be covered in junk.
04/11/2021 at 23:13 #164246Mike
Keymaster08/11/2021 at 04:29 #1643606mmwargaming
ParticipantThe first two buildings are finished and I’m starting on a third. I found a much better scifi font stencil and it has come out really well. I’m really pleased with the building colours as they are pretty bright but washed out.
Most of the painting was done with an airbrush first and then the details were painted. I went over it with a thin brown airbrush coat to blend the pieces together where the greebles joined the blue/green base colours, and to add some dirt to the bottom of the buildings.
Sorry for the picture quality as the lighting was pretty poor
08/11/2021 at 06:50 #164361Jim Webster
ParticipantWell I like them, the added clutter really makes them!
Lovely bit of workhttps://jimssfnovelsandwargamerules.wordpress.com/
08/11/2021 at 16:18 #164396OldBen1
ParticipantHoly cow! That’s unbelievably awesome. It looks real.
09/11/2021 at 02:49 #164425Cacique Caribe
ParticipantStunning results! I’ll have to copy some of these ideas soon.
Dan
Loads of WIPs: https://www.flickr.com/photos/[email protected]/albums/with/7215771063052937611/11/2021 at 07:09 #1645166mmwargaming
ParticipantCheers
Here is the next build – I’m calling it a shop (of sorts). The brown sign at the front is magnetised and can be swapped out. I haven’t figured out what to do with the sign yet.
11/11/2021 at 21:24 #164568Cacique Caribe
ParticipantWhy not a robot repair shop? 🙂
Dan
Loads of WIPs: https://www.flickr.com/photos/[email protected]/albums/with/7215771063052937612/11/2021 at 05:33 #1645776mmwargaming
That’s a great idea! I have lots of left over pieces so i was thinking about some junk piles.
12/11/2021 at 06:06 #164578Cacique Caribe
ParticipantAnd you could make some simple droids sitting by, waiting for repair:
https://leadadventureforum.com/index.php?topic=93659.0
http://theminiaturespage.com/boards/msg.mv?id=337107
Dan
Loads of WIPs: https://www.flickr.com/photos/[email protected]/albums/with/7215771063052937612/11/2021 at 07:54 #164579Geof Downton
Or a workshop making buildings from recycled materials…
(Sorry, couldn’t help it!)
Ahab, King of Israel; 1 Kings 20:1113/11/2021 at 20:24 #1646376mmwargaming
Or a workshop making buildings from recycled materials… (Sorry, couldn’t help it!)
lol, or a recycling shop. I am planning a vehicle repair shop as well but that will have a gantry and lots of spare parts lying around.
13/11/2021 at 20:29 #1646386mmwargaming
Participant13/11/2021 at 20:38 #1646396mmwargaming
Participant13/11/2021 at 22:44 #164642Jim Jackaman
ParticipantThat looks great! Top work.
16/11/2021 at 00:19 #1647226mmwargaming
ParticipantThanks
I’ve moved on to walls now to keep the population in, or the wildlife out!
These were constructed using 3 and 6mm forex, along with Mantic bases and some wooden dowel. I had lots of Mantic spare bases and I really like the look when they are all glued down. Also they have lots of lights so nothing shady goes on next to the walls.
Also I created two terminals, which are made from a Dungeons and laser piece, which sits on top of some random figure bases.
