Home › Forums › General › Game Design › Portable Wargame, am I making it too complicated?
- This topic has 14 replies, 10 voices, and was last updated 2 years, 8 months ago by
Andrew Beasley.
29/03/2021 at 22:40 #154453
JozisTinMan
ParticipantOk, I have 2 travel battle board sets painted up and a couple of 6mm armies mounted on 20mm squares. (Normans and Orcs right now) So… I am stuck thinking about how to track hits on the little bases. Of course, I thought about 3d printing a solution, but I cannot think of an elegant way to show hits.
Am I just making it too complicated and I should just use a roster? Thoughts? I am trapped by analysis paralysis.
30/03/2021 at 00:22 #154454Thaddeus Blanchette
ParticipantFor a portable game, I’d go with a roster. Otherwise the casualty tracker markers are liable to be too visually disturbing.
However, if you can make legible diaorama style casualty markers (i.e. dead guys on a base), that might be worth a go.
30/03/2021 at 04:29 #154455Logain
ParticipantBaccus 6mm casualties!
30/03/2021 at 07:50 #154456MartinR
ParticipantI just put tile spacers on the bases for individual SP and keep track of overall losses to determine exhaustion using a deck of cards (give each side a number of cards equal to exhaustion and remove one per hit).
Yes, you could use a roster, or little dice, but I tend to knock little dice over with my big fat fingers.
30/03/2021 at 08:26 #154457Shaun Travers
ParticipantYes, you are a bit stuck there. I use hit markers that about 10mmx10mm for my 6mm portable games so not attractive all all. Cannot think of an on table solution that would blend in. Sorry!
30/03/2021 at 09:29 #154458Blackhat
ParticipantUse the “instant” death version and you don’t have to track anything! I also don’t use exhaustion point as I don’t see how it works as written and always use scenarios with a fixed game length.
30/03/2021 at 12:56 #154464Sane Max
ParticipantThere’s a similar thread about this elsewhere – I generally find markers too obtrusive whatever I do, at that scale you really are stuck. I would second the ‘use a roster’ method.
If it doesn’t take up too much room, how about a peg board like you used to get in the Mastermind Boardgame? something like a Cribbage Board?
30/03/2021 at 14:33 #154465Thaddeus Blanchette
ParticipantLittle tiny plastic blood drops by Litko might work.
31/03/2021 at 01:13 #154484Who Asked This Joker
ParticipantHi Patrick,
Have you considered a numeric counter? Just place it under the base. When you need to see or change it, just pick up the base and read/remove the counter and replace it with the appropriate number. That will probably be the best, non-roster solution. Otherwise, I think you are doomed to a roster or some ugly counters.
John
John
--Abraham Lincoln
31/03/2021 at 11:32 #154504Sane Max
Participantahh I dislike that concept. it’s the basic concept for Fire and Fury, and we ALL found it annoying picking up bases, putting them back, dropping them, forgetting what we had just read, doing it again – we eventually gave up on aesthetics and used strips of post-it-note sticking out the back of the base for ease of reference. Ugly as heck but much less of a pain.
YMMV of course
31/03/2021 at 11:43 #154507MartinR
ParticipantI was just about to suggest a sticky strip protruding from the back. Just blob the hits on the bit of paper with a sharpie.
If you fold printing labels they stick quite well and have a nice surface to write on.
I usually put an 8mmx8mm square of magnetic tape on all my bases so I can attach labels, strength point markers etc, but it is a bit late for that as you’ve already done the bases.
31/03/2021 at 11:51 #154508Sane Max
Participantyah, I bought these for £2.00 at The Works.
31/03/2021 at 15:49 #154524Mike
Keymaster02/04/2021 at 16:00 #154629JozisTinMan
ParticipantHey guys! Sorry, I was out of town a couple of days. Thanks for all the great replies.
I think the answer is yes, I am making it too complicated…
- I thought about 3d printing numbered markers and may try that. I am worried that it may be fiddly, but I need to try it before dismissing it.
- I think I will start out with a paper roster BUT…
- … if I do stay the roster course, I like the master mind board idea above and could print that.
The other option is to go 1 hit or 2 hit option in the rules, which is where I shall probably start because it is the path of least resistance. I’ll post how it goes.
PS- Hi John! I am looking forward to the conventions starting up again and we can push some lead again.
02/04/2021 at 17:09 #154633Andrew Beasley
ParticipantI’ve fallen back to paper for one hour wargames (each unit takes 15 hits to remove) and colouring the edges of bases to identify the units (e.g. red / blue infantry etc) and been happy with that.
I’ve wondered about dropping down to two / three ‘hits’ per unit as I’ve found my plastic rings again and have fire / smoke markers for more modern games.
How do you find the Battle boards? I’ve had my eye on them since they came out and noticed you can buy them without the boards direct from Perry Miniatures. My only concern is the fixed scenery – totally in the wrong place for ALL of the 30 provided scenarios!
