Home › Forums › Horse and Musket › Napoleonic › Russian Order of Battle at Eylau, 1807
- This topic has 13 replies, 3 voices, and was last updated 8 years, 11 months ago by
Jonathan Gingerich.
14/10/2014 at 07:43 #10609
Bandit
ParticipantI’m comparing the following sources:
James Arnold
Petre
Digby Smith
WikipediaWhy Wikipedia? Because it cites the Russian language source Vasil’ev*.
All of these are vastly different. Anyone have any reasons to share as to why one might be better than another? Specifically for the Russians.
* AA, “COMPOSITION of ALLIED TROOPS at EYLAU: List of the Allied Russian and Prussian troops participating in the Battle of Preussisch-Eylau January 26 and 27 (February 7 and 8) 1807”, Imperator No. 11 pp. 11–14 (2007)
19/10/2014 at 18:41 #10905Jonathan Gingerich
ParticipantThanks for the reference. This contribution by Vasilyev doesn’t seem to be very widely disseminated.
I assume asking whether to go with Petre, Smith, Arnold, or Vasilyev for a Russian OB is merely rhetorical?
I don’t have most of those, can you point out some of the most glaring differences?
20/10/2014 at 01:32 #10917Bandit
ParticipantI assume asking whether to go with Petre, Smith, Arnold, or Vasilyev for a Russian OB is merely rhetorical?
Well, it wasn’t meant to be but perhaps it has become so :-p
Arnold and Vasilyev vary the most. It would seem that Vasilyev is referring to the organization prior to the battle while Arnold makes it clear he is talking about the organization at the battle. The biggest differences would be that Vasilyev has the cavalry brigades and artillery batteries assigned to their parent divisions while Arnold has them grouped as separately integrated commands. There are also some differences with the infantry brigade and division assignments. Digby Smith seems to be following Vasilyev. Arnold’s order of battle (mostly) jives better with the location of units on the field.
20/10/2014 at 07:54 #10922Cerdic
ParticipantSounds like a right old can of worms……
20/10/2014 at 22:15 #10989Jonathan Gingerich
ParticipantAh, I thought you were suggesting there were unit level discrepancies.
I would suggest going with Arnold, as the Wikipedia compilation does not integrate Vasilyev’s notes.
06/11/2014 at 19:38 #12158Jonathan Gingerich
ParticipantWell I just read Crisis in the Snows and I’ve got ahold of Imperator too. Tricky. Vasilyev has some excellent information on who was actually commanding, but blows some easy ones like including the 26th Jaeger or some of the Don Cossack regts. who weren’t there. Arnold offers the actually higher level command structure on the day of battle, but doesn’t get into the brigading. And he misses some of the things Vasilyev uncovered. Neither is definitive.
07/11/2014 at 04:42 #12187Jonathan Gingerich
ParticipantI’ve discovered Reinertsen has discussed a lot of the issues on Napoleon-series.org and it’s very persuasive.
07/11/2014 at 18:28 #12243Bandit
Participant07/11/2014 at 20:54 #12257Jonathan Gingerich
ParticipantWell remember if you drop site:napoleon-series.org into a Google search, it will search just that site.
11/12/2014 at 00:03 #13852Jonathan Gingerich
ParticipantI’ve just posted a Russian OB for Eylau – it’s a synthesis of Arnold & Reinertsen’s structure with Vasilyev’s commanders. Take a look and see what you think.
12/12/2014 at 17:01 #13906Bandit
ParticipantJonathan,
Your composite of them is a heck of a lot better cited than mine is. Your conclusions and mine differ in a handful of ways. In broad strokes here is what I’ve got:
Right Wing: Tuchkov
5th Division: Foch
Former Rearguard (brigade detached from 7th Division): Markov ICenter (3rd Division): Osten-Sacken I
Brigade: Titov II
Brigade: Dolgorukov VCenter (8th Division): Essen III
Cavalry Brigade: Glebov-Streshnev
Infantry Brigade: Engelhardt I
Infantry Brigade: LevitskyLeft Wing: Ostermann-Tolstoi
2nd Division: Sukin II
6th Division: BaggovutReserves: Dokhturov
4th Division: Somov
7th Division: Zapol’skiiFor artillery commanders running the grand batteries I’ve got: Sievers, Löwenstern and Stavitsky I.The other formations I’m not listing line up almost completely with yours.
One quandary is that Pahen III is commanding the cavalry on one wing while commanding a brigade on the other wing subordinate to someone… You able to figure anything out about that?
I think the largest difference between yours and mine is that I don’t conclude that Essen III reports to Tuchkov I but that they each ran separate commands. I *think* I concluded that from something I read in Arnold but it was months ago and I am foggy.
12/12/2014 at 22:44 #13911Jonathan Gingerich
ParticipantBandit,
A.&R. mention that the Russian divisions were grouped in corps sometime in the prior days. Unfortunately they don’t specify what they were, but it seems clear the 5th and 8th formed a corps under Tuchkov, at least nominally. Not sure how it worked in practise.
Fock was an adjutant, so it seems reasonable that he would be put in charge of the 5th division once Tuchkov was promoted. Vasilyev has him subordinate to Rezvyy, but I will have to more carefully translate [i.e. not just drop it in Google] the St George commendation – it may indicate he was in charge of infantry and not the battery.
I applied my own guesses to the 3d Div as neither A.&R. nor V. are convincing.
Sukin-2 taking charge of the 2d division is perfectly plausible although neither A.&r. nor V. suggest it. Can you dig up any data?
Same for Zapolsky and the 7th?
Sievers was chief of the 5th Artillery Brigade, but Kutaisov was definitely at the battle and would have outranked him. If Fock is not commanding the center battery, then Loewenstern would most likely be there. Stavitsky was chief of the 2d Artillery Brigade and would likely be second to Rezvyy if present. But would he rather run around with his horse company?
I have Pahlen-3 on the right. I notice I forgot to mention my conventions – italic when officers are formally located but not physically present and ()’s where they are taking additional responsibilities.
14/12/2014 at 03:33 #13940Bandit
ParticipantSukin-2 taking charge of the 2d division is perfectly plausible although neither A.&r. nor V. suggest it. Can you dig up any data?
These two were conjecture on my part.
The artillery I believe I drew from Arnold.
14/12/2014 at 18:51 #13975Jonathan Gingerich
ParticipantI’ve revised it to have Fock commanding the 5th division, and Loewenstern in the center. I think that makes us essentially congruent.
My post on Napoleon-Series got more than 100 hits after Alexandre announced it on TMP. And I’m basking in the reflected glow of all those thank yous!
