- This topic has 2 replies, 2 voices, and was last updated 6 years, 7 months ago by .
Home › Forums › Horse and Musket › Napoleonic › Russian rear area vehicles
In Et sans résultat! it is important to indicate the rear area of a division which acts as the rally point for routed units, a resupply point for depleted artillery, and a marker to symbolize the rear of the division should it be threatened by the enemy.
It’s nice to dress these up a bit and show off some models on the tabletop that we don’t normally get to see in games, such as caissons, supply vehicles, and the like. Here are three I recently finished for mid and late war Russians. Hope you like them.
The Bandit
I don’t usually bother with caissons, but I use limbers to bulk out my Napoleonic artillery bases. I used to use 60mm wide by 30mm deep artillery bases with 4 guns plus crew. I found that it was difficult not to manoeuvre directly behind the artillery, which I believe to be very unrealistic. I went over to using 60mm wide by 80mm deep bases with limbers behind the guns, to discourage that.
