Home › Forums › Air and Sea › Naval › Self Made Sea Bases
- This topic has 12 replies, 8 voices, and was last updated 5 years, 6 months ago by cmnash.
27/09/2018 at 10:42 #100290cmnashParticipant
For my RJW 1/2400 ships, I’ve been making my own sea bases using PVA soaked toilet tissue:
I’m very pleased with how they have turned out; here’s one in close-up:
Unfortunately, the printer I used for the name labels is not the best quality, so I intend to replace them when I can access a better printer
27/09/2018 at 11:45 #100295EtrangerParticipantThey look good.
27/09/2018 at 12:21 #100296Brendan MorrisseyParticipantYou seem to have covered up the brown stains pretty well.
(Sorry. They do look rather good, actually.)
27/09/2018 at 18:25 #100322kyoteblueParticipantThey look good.
27/09/2018 at 20:19 #100328hammurabi70ParticipantI’ve been making my own sea bases using PVA soaked toilet tissue
I am not understanding this; how does one do it?
www.olivercromwell.org; www.battlefieldstrust.com
6mm wargames group: [email protected]; 2mm wargames group: [email protected]27/09/2018 at 22:11 #100334Norm SParticipantThat works well.
28/09/2018 at 08:00 #100353cmnashParticipantI’ve been making my own sea bases using PVA soaked toilet tissue I am not understanding this; how does one do it?
Hmmm … that probably wasn’t the best way to put it actually – sorry about that.
After gluing the ship model to an mdf base (for the RJW ships they are 6cm x 3cm x 3mm), I ‘paint’ the base with a PVA solution and then put a strip of the tissue onto the glue. Then ‘paint’ the top with more PVA solution. When the tissue is thoroughly wet, push it into ‘waves’ with a blunt edge (a sharp edge will just rip it).
I then leave it overnight to dry, tidy up the edges with a knife and then spray undercoat the whole thing.
28/09/2018 at 09:10 #100355hammurabi70ParticipantVery impressive. Not sure how you make the underlying sea terrain fit in in the same way!
6mm wargames group: [email protected]; 2mm wargames group: [email protected]28/09/2018 at 09:53 #100360cmnashParticipantVery impressive. Not sure how you make the underlying sea terrain fit in in the same way!
I’ve got a sea mat from Tiny Wargames. I think they’ll be a pretty good match, but actually haven’t put them on it yet …
29/09/2018 at 11:33 #100434Jim JackamanParticipantVery effective. What’s your recipe for the shade of blue?
01/10/2018 at 08:38 #100514cmnashParticipantVery effective. What’s your recipe for the shade of blue?
It’s a tester pot of ‘Royal Sapphire’ from Wickes – https://www.wickes.co.uk/Wickes-Colour-@-Home-Vinyl-Matt-Emulsion-Paint—Royal-Sapphire-2-5L/p/122310
and then a wash of Coat d’Arm’s ‘Green-Grey’
with 2 coats of gloss varnish (the tin said 3 coats, but I stopped at 2)
11/10/2018 at 15:49 #101281VolunteerParticipantDo you mean like the eraser end of a pencil? Or what?
They look pretty good at that scale.
"Research is what I’m doing when I don’t know what I’m doing"
Wernher von Braun11/10/2018 at 16:10 #101284cmnashParticipantDo you mean like the eraser end of a pencil? Or what? They look pretty good at that scale.
Thanks. I was using an old size 3 (I think!) paint brush to put the diluted PVA on the base, and used the other end of the brush to move the tissue around.
