- This topic has 1 reply, 2 voices, and was last updated 6 years, 2 months ago by .
Home › Forums › Sci Fi › 15mm Sci-Fi › Steam Tank – Tesla Coil Gun
Hi All,
Many of you may not of heard of Conqueror Models, as this is a relatively new venture that offers various ranges of models mainly models of what I want and game with as for teh most part I 2d design and print myown models. But most recently and of much more interest to this forum is our expanding range of 15mm Steam Tanks and accessories based around WW1 vehicles- emminently suitable for AQOTMF or such games.
Below is the Tesla Coil Gun Steam Tank which has only just been released – hope you like.
Based on the British MKIV World War I tank this is an alternate version using Steam power.
The Turbine engine to generate the Tesla charge has been “containerised” (its a thing with any army they cannot help but containerise everything!) in an armoured trailer. This helps protect the generator from enemy attacks, the generator is isolated with the inside of the trailer coated with 1/2″ of ceramic, with good old fashioned steel providing the outer protection. Two large heavily insulated cables connect the generator to the Tesla Coil gun <span class=”text_exposed_show”>on the rapidly converted Mobile Howitzer Tank</span>
Excellent fields of fire are possible as the Tesla coil gun is post mounted as there is no recoil when fired.
All models are supplied unpainted
This variant also has the added protection of an HMG turret mount.
NOTE: The cables from the trailer to the main tank are not supplied – the hole for the cable is 1.5mm Diameter and brass/copper rods are easily and cheaply obtained and can be bent into required shape.
