- This topic has 16 replies, 12 voices, and was last updated 5 years, 5 months ago by
kyoteblue.
31/07/2015 at 21:51 #28399
Bruce Ross
ParticipantHello all
I’m going to start ww2 mini gaming, solo (by choice) and I’m looking for larger engagements (20-30 vehicles and several hundred men on the table at a time).
Not sure if I can do this with 10mm. I know 6mm will work, but I’m afraid 6mm is just too small.
Chime in if you had this dilemma and what you chose.
Thanks
31/07/2015 at 22:33 #28400Norm S
ParticipantI go with 10mm because the vehicle footprints are still reasonable, whilst the infantry are also good.
I have been distracted lately by 20mm, simply because of the aesthetic and for the first time I actually enjoy painting something
but the reality is that on my small table, 10mm is the way for me to go.
This article might interest you LINK
also this is the third article that looks a bit more at 10mm as an alternative to 6mm LINK
31/07/2015 at 23:11 #28406Mr. Average
ParticipantI’m sorry to differ with you on the issue of 6mm scale’s being too small. I’m fact I think it’s well recommended for the size of engagement you’re looking at. Though I agree 10mm has a lot to recommend it I think you’ll find it too large for engagements of several hundred men. Although to be sure a lot depends on the gaming space as well – how big a table will you have available?
31/07/2015 at 23:23 #28407Bruce Ross
ParticipantMy table will roughly be 4’x6′ maybe 4’x8′
31/07/2015 at 23:31 #28408Mr. Average
Participant31/07/2015 at 23:35 #28409Bruce Ross
ParticipantI think it’s just my love affair with larger scales….for the most part, they look better (GHQ stuff looks better than a lot of 10mm stuff), but I’m not model kit building….I’m war gaming. If I think about that, then it’s a clear and easy decision.
6mm
01/08/2015 at 01:34 #28418Just Jack
ParticipantI’m on my phone, so can’t post a link, but if you go to my blog (from one of the ‘Cuba Libre’ posts), look at the right side for tags, then select ‘Hell on Wheels,’ you’ll see some battalion-level (1 stand/vehicle equals 1 squad/vehicle) fights on an 8′ x 6′ table.
Not as many vehicles as you’re looking for, but should give you an idea. I love 10mm, but for the size engagements you’re tLking about, I’d go 6mm and platoon base them.
Actually, I did! 😉
So if you go to my blog and hit the tag ‘5Core Brigade Command, you can see pictures of modern NATO and WarPac 6mm that is platoon-based (3 vehicles per base).
Hope it helps.
Jack
01/08/2015 at 05:08 #28424Shaun Travers
ParticipantI went for 6mm to play on small (2’x’3′ and 2’x2′) tables. I only play with about 3-8 tanks. I believe for your size table and the number of vehicles, 6mm would be the way to go. 10mm is a good size, but I think you would have to scale back the number of vehicles to make it look ok. My opinion only of course!
01/08/2015 at 07:15 #28428Steve Johnson
Participant10mm would be my recommendation. I play on a 6’x4′ table for larger games of BKCII, which easily accomodates 20 – 30 vehicles. In terms of infantry there would probably be 30 -40 stands (total for both sides). Having played CWC with 6mm vehicles, once based (for protection) they take up a similar area as unbased 10mm. Hope this helps?
01/08/2015 at 15:57 #28451Mike Harrop
ParticipantI’d suggest the Battlegroup rules at 6mm, 1:1 tanks and infantry and looks good with between 5-50 vehicles and loads of infantry per side
"This lighthouse is under attack, and by morning we may all be dead!" The 4th Doctor - Horror of Fang Rock
02/08/2015 at 03:50 #28473kyoteblue
ParticipantI game every thing in 15mm, that way, my terrain works for every thing.
23/09/2015 at 11:42 #31516simon ford
ParticipantI do all my gaming in 20mm but then I am fortunate to have a table that is 27 feet long by 5.5 wide. I can’t figure out how to post photos here but if you are on Facebook I have a closed page, feel free to ask to join, Wargameroz’s 20mm Ramblings lots of pictures etc
23/09/2015 at 12:41 #31518irishserb
ParticipantHi, I have a modular table, so game on a 4’x6′ or 6’x9′ table most of the time, I have gamed WWII with 6, 15, 20, and 28mm figs over the years. I currently game with 6mm and 15mm for WWII with using 1 to 1 vehicle representation and fire team basing for 6mm, (everything is 1 to 1 individual basing for 15mm). I would heavily recommend the 6mm route given your table size. The smaller scale will give you greatly flexibility with respect to the scope of your battles, and would better fit the smaller table size limits. 3mm might be a consideration, though for me is small enough that it gets hard to identify at a more than a couple of feet distance.
23/09/2015 at 13:24 #31519willz
I am sooooooooooooooooo jealous, you lucky sod
any chance of some photo’s so I can lick the screen and dream
Ditto on 20mm for me is the only scale, though that might be a throw back from sixties as that’s all you could buy. If I was starting all over I might be tempted with 15mm as there is such a vast choice and stowage is almost half the space as 20mm.
23/09/2015 at 14:20 #31528simon ford
ParticipantWilliam
i havent figured out out how to do it from my iPad, but look up Wagameroz’s 20mm Ramblings on Facebook and ask to join, lots of stuff on there
simon
26/09/2015 at 11:48 #31658NTM
Same here. If starting from scratch today I’d probably go 10mm but life’s too short to go about buying and painting a whole new lot of terrain and scenics.
26/09/2015 at 19:19 #31661kyoteblue
ParticipantMy 15mm terrain works with almost all of my 15mm periods …. so If you don’t want to spend a lot on terrain and troops go 6mm…. and just give me all your useless 15mm stuff…..wink wink.
