Home › Forums › Horse and Musket › Napoleonic › Well, that was odd
- This topic has 46 replies, 13 voices, and was last updated 11 months ago by
OotKust.
16/04/2021 at 20:35 #155215
Jonathan Gingerich
ParticipantI avoid contributing The Miniatures Page (for reasons we shan’t discuss here), but I do keep an eye on the Napoleonics folder, esp. the Russians. There’s always the possibility of new information, or at least some hints to where I might be able to improve my own page. I’m watching the discussion of blackened equipment for the Russian Jaegers. So far, it seems it’s pretty well covered on my web page. Then yesterday von Winterfeldt posts a link to my page with a brief endorsement. This morning…not a hint it was ever there… (Meanwhile, several paragraphs cut-and-pasted without attribution from Mark Conrad’s translation of Viskovatov remain immediately prior.)
If you want to check it out yourself: https://zaotlichiye.000webhostapp.com/allfacings.html
17/04/2021 at 09:10 #155223Oh no….
ParticipantSounds like one of you may have upset someone!
17/04/2021 at 09:47 #155224MartinR
ParticipantOr it is a bug and the post vanished when the site did its arcane overnight database reindex.
07/05/2021 at 22:31 #156030AdmiralHawke
ParticipantPosts disappear all the time. It’s a policy, not a bug.
Fortunately this forum exists instead. 😉
08/05/2021 at 06:51 #156035mark leslie
ParticipantAlways best to stay mum, lest the “bug” come for you.
Fossilizing nicely.
04/05/2022 at 22:24 #172417OotKust
How apposite!
First use of that word since becoming an annointed ‘pensioner’ !
d
05/05/2022 at 00:35 #172422Etranger
ParticipantYou aren’t alone in having this happen Jonathon. The Admiral makes a valid point.
05/05/2022 at 01:05 #172423Guy Farrish
ParticipantThat’s odd- with your link I’m repeatedly getting:
This site can’t be reached
zaotlichiye.000webhostapp.com took too long to respond.Try:
Checking the connection
Checking the proxy and the firewall
Running Windows Network Diagnostics
ERR_CONNECTION_TIMED_OUTUsing Windows 10 and Chrome.
No problems elsewhere my end that I can see.
05/05/2022 at 01:19 #172424OotKust
ParticipantCan’t edit other peoples links, but he was dissed by his servers back then so is now next door… use:
https://kiver.000webhostapp.com/index.html and the info you want
cheers dave
05/05/2022 at 11:17 #172439Guy Farrish
ParticipantI knew that!
Late and didn’t check the age of the post.
Thanks for the gentle reminder.
However I’m still getting this:
kiver.000webhostapp.com took too long to respond.Try:
ERR_CONNECTION_TIMED_OUT(which is what happened when Jonathan changed servers – no idea why I can’t access this still)
06/05/2022 at 09:35 #172480OotKust
ParticipantWell sorry, I got there yesterday as I check links before reposting anything, probably an ‘other’ access issue if hes actually hosting from Ruzzia as well 🙁
Ive learned to save such data/ info pages, just in case…
d
Update edit*** It finally resolved again after about two minutes; clear your cache and try again??
06/05/2022 at 09:54 #172481Mike
Keymaster06/05/2022 at 11:18 #172483Guy Farrish
ParticipantVery weird.
Still taking too long to respond. Cleared cache, ran windows diagnostics, everything appears to be okay my end and no problems connecting anywhere else.
Hmm?
Obviously something I’m running but what?
I must have a prod about.
06/05/2022 at 22:26 #172517OotKust
ParticipantObviously something I’m running but what? I must have a prod about.
**Edit** I had a similar prob with tww as well for a few hours.
Perhaps but then these ‘in between pipes’ are subject to a lot of interference of the ignorant and nasty kinds, so you can’t tell. Our own Windsor based govt. has ‘upgraded’ their ‘social support’ systems recently and disenfranchised old comps, old browsers, and doesn’t play nice at all.
Need to use 2FA? No problem, we’ll send your codes (multiple) in about 14 hours!
Wonderful way to treat ppl. I was acting in IT (user interface and UAT) when I was shoved out the 19th story window… big business/ monopoly has a lot to answer for…
Just for laughs try out Ghostery ‘Dawn’ (privacy) browser. it’s quite good and keeps a few creepers and bugs out/ away.
https://www.ghostery.com/ghostery-manifesto
cheers d
12/07/2022 at 23:04 #175635OotKust
Participant~~ main subject site whacked again?
Just when you want an easy look up… back to the backups … good lock jono…
12/07/2022 at 23:15 #175636kyoteblue
ParticipantThe Bug rules a certain site…
15/07/2022 at 16:10 #175758Greystreak
ParticipantJonathan, it appears your site has been taken off-the-air again . . . any news you can share?
Bryce Allen
15/07/2022 at 16:54 #175771General Slade
ParticipantIt’s still there. You just need to click on the link at the top of the landing page. Or you can go directly to the page here: https://kiver.000webhostapp.com/allfacings.html
Edit: That’s odd – when I click on my own lick the page isn’t there. But I can still get it when I use the book mark in my browser or click on the link at the top of Greystreak’s link.
Another edit: Now I can’t get it at all.
15/07/2022 at 16:56 #175772Mike
Keymaster15/07/2022 at 16:57 #175773Mike
KeymasterDown detector says site not up either:
https://www.isitdownrightnow.com/kiver.000webhostapp.com.html
You got a cached page or something?
15/07/2022 at 16:59 #175774General Slade
ParticipantIt must be something like that because I could call up the page successfully two minutes ago but it has now disappeared completely.
18/07/2022 at 15:30 #175865Greystreak
ParticipantSeems like the site is back up at its same location now: https://kiver.000webhostapp.com/allfacings.html .
All’s well, then.
Bryce Allen
18/07/2022 at 15:33 #175867Mike
Keymaster18/07/2022 at 15:36 #175868General Slade
ParticipantIt’s working for me again, both going from Greystreak’s link and my old bookmark.
18/07/2022 at 15:39 #175869Mike
Keymaster18/07/2022 at 15:43 #175871General Slade
ParticipantNow it’s disappeared again for me and I’m getting the same message as you Mike.
18/07/2022 at 15:46 #175872Guy Farrish
ParticipantI’m getting ‘too long to respond’ on Google and Edge.
18/07/2022 at 16:01 #175873Mike
Keymaster18/07/2022 at 16:03 #175874Robert Armstrong
ParticipantNever seen behaviour quite this weird for a web page – it opened for me at 16:00, but tried opening it in another tab on the same browser at 16:01 and ‘no such website’…
Never visited it before so it can’t be a cacheing thing.
18/07/2022 at 16:23 #175876Mike
Keymaster18/07/2022 at 16:43 #175879Mike
Keymasterhttps://ln5.sync.com/dl/972046550/nwuz5jjr-xt6wbq2i-ew5nu3gt-8u3ae68q
Hopefully the above link will let you DL the file and then once you have saved it you can open it with your browser.
19/07/2022 at 08:37 #175891General Slade
ParticipantThanks Mike,
That works for me. Hopefully Jonathan will be able to find a new host soon. It is a wonderful site and I refer to it often.
19/07/2022 at 11:27 #175897OotKust
ParticipantThanks Mike, That works for me. Hopefully Jonathan will be able to find a new host soon. It is a wonderful site and I refer to it often.
Anyone emailed him direct lately?
I had earlier which prompted his multiple replies… d
20/07/2022 at 19:47 #175959OotKust
Participant… and they’re back_ at least temporarily_ or on this side of the planet ../
21/07/2022 at 02:24 #175962Guy Farrish
ParticipantNot in blighty it’s not. Still getting err connection timed out here.
21/07/2022 at 09:05 #175969General Slade
ParticipantIt’s working in this corner of Blighty.
21/07/2022 at 14:55 #175996Guy Farrish
ParticipantWeird.
Still timeout error for me. On a different computer than in May when I couldn’t connect. Using a different AV package. Cleared everything. Diagnostics say the wifi connection is working, broadband internet connection ok but target server not responding. No known problem with any other sites.
Can’t be right – maybe it’s me!
21/07/2022 at 15:45 #17599821/07/2022 at 19:15 #176003OotKust
ParticipantCan’t be right – maybe it’s me!
Nope not really. The site is messing around.
I noticed that it must have multiple servers/ service as the page icons changed- when on old server it was one thing; changed to next; now all back to original icon; i cant be assed doing TraceRoute coz as I say, I’ve saved copies (and there is the backupski system) for my use anyway.
The perils of using a remote AP and ‘free’ at their mercy. Mike why don’t you just host him on here, can’t cost too much and the ads revenue may increase because of it?
BTW just on the content- Facings especially, often overlooked but important here, you really do need to consult the referenced footnotes thoroughly. They range from simple abbrevaited citations to expansive dissertations with illustrations, so JG really does his homework, and sets out to define what he can, and more importantly can’t, clearly!
cheers dave
30/07/2022 at 00:39 #176315Jonathan Gingerich
ParticipantHI guys, sorry been a bit preoccupied of late.
Are you still having issues? May have to find someone other than Cypriots to host me…
