Home › Forums › Air and Sea › Naval › What Do You Use for Bases?
- This topic has 6 replies, 6 voices, and was last updated 6 years, 3 months ago by
willz.
20/04/2016 at 01:19 #40889
Darryl Smith
ParticipantI am looking for suggestions to mount some 1/3000 scale ships for the Battle of Lemnos (Balkan War – 1913) and am curious to what folks are using for basing their ships. Looking for companies that make bases, how you might have finished your bases, pics of finished bases, etc., etc. The largest ship for this battle is less than 2″ long so wanting something that will fit the ship with a bit of cushion all around to protect the miniature, and perhaps leave a bit of room for a national flag on the base or a ship name.
A short post on my blog about this project might give more info…but not much! 🙂
Buckeye Six Actual
https://ambushedinthealley.blogspot.com/
http://foragecaps.blogspot.com/
http://germancolonialgaming.blogspot.com/20/04/2016 at 03:06 #40895Altius
ParticipantLately, I’m using Litko laser-cut wooden bases quite a bit, and sometimes Renedra plastic bases. I used to simply cut my bases from sheets of matte board but the Litko bases are so much nicer and worth the extra cost.
I don’t do a lot of ships, but here are some photos of some triremes I painted.
https://studiovalidus.wordpress.com/2013/12/04/the-punic-war-at-sea/
As you can see from the photos, I made some bases for them with matte board. I wanted to give the bases some interesting three-dimensional “texture” so I used a thickening gel (from an art supply store) to create the chop and wakes.
Where there is fire, we will carry gasoline
20/04/2016 at 05:16 #40898Schlesien
ParticipantI just use thin strips of bass wood cut to fit. I used to use put cut blue water sheet on top (in photo link below), but I now just put gloss gel medium. I then print out labels and glue them to the sides of the base on both sides.
Example: Photo of 1:3000 ship on base
20/04/2016 at 09:18 #40908Northern Monkey
Participantto save money I use artists mounting card with milliput on top, cheap, easy and durable, a few pics of the ones I did for my 1/1200th naval stuff here:
http://ablogofwar.blogspot.co.uk/2016/01/napoleonic-naval-11200th-part-1-british.html
My attempt at a Blog: http://ablogofwar.blogspot.co.uk/
20/04/2016 at 14:22 #40931Darryl Smith
ParticipantSome good ideas there…I like the thick bases for the name display, but they also probably would stick up rather tall over the gaming mat.
Are there clear bases out there that one could use? Would save me painting and texturing the bases, and allow the pretty gaming mat to show through.
Buckeye Six Actual
http://germancolonialgaming.blogspot.com/20/04/2016 at 14:37 #40935Gaz045
ParticipantI have used plasticard, usually a pretty thin one, I have also got some blue coloured ‘industrial’ nylon plastic that I have used……..and just painted on the wake etc……
I would investigate the clear plastic or ‘acetate’ that is available for model railway buildings windows and dolls houses…..one sheet should ‘fix’ a lot of ships!
There was a recent ‘press release’ for clear bases……but can’t recall where I saw it!
srs
20/04/2016 at 17:40 #40971willz
ParticipantI used to use thin 3ply wood, now I have progressed to laser cut bases from “War Bases” or “Colonel Bills”. like Northern Monkey I do use artist grey board, it about £2 for a sheet some 2 x 3 foot. Mainly I use that for WW2 basing but it can warp if you use the wrong basing material. Like I said I mainly use laser cut MDF bases they don’t warp.
