- This topic has 17 replies, 14 voices, and was last updated 5 years, 6 months ago by
McLaddie.
16/08/2015 at 23:38 #29350
Bandit
Participant16/08/2015 at 23:41 #29351Mr. Average
Participant16/08/2015 at 23:55 #29352Mike
Keymaster17/08/2015 at 00:12 #29353grizzlymc
ParticipantRubberise magnet for 3 cav or 4 inf, then a 1mm thick steel movement tray for the Bn.
17/08/2015 at 00:18 #29354Bandit
Where do you source em? Cut em yourself from sheet?
The Bandit
17/08/2015 at 00:34 #29355grizzlymc
ParticipantI buy the rubberised magnet from craft shops and draw on the white side, cut with heavy dutty scissors.
TThe steel bases I bought years ago from a levantine jew, but any metal shop could make them up, zinc wipe them then paint with oil based paints to avoid rust.
If you do obscenely large scales, you could base your figs on steel and either stick magnet underneath or put it on a movement tray.
17/08/2015 at 03:45 #29364Thaddeus Blanchette
ParticipantSimple matte board, but the. Again, I mostly play micro and pico scales, so I don’t worry so much about magnetically attaching things for storage.
17/08/2015 at 03:50 #29366kyoteblue
ParticipantFor individual figures metal washers, for multi figure stands FOW bases for my DBA/M metal bases.
17/08/2015 at 03:57 #29367Mr. Average
Participant17/08/2015 at 04:08 #29368Lagartija Mike
SpectatorSteel bases, regardless of scale.
17/08/2015 at 06:17 #29371Norm S
ParticipantPreviously – always artists board hand cut (form any art shop – the material used in frame mounts)
Now,
Artist board for 10mm WWII (it has a shallow step for the small figure and easy to cut to size for a variety of vehicle types)
or if I am using 12mm Kallistra, I use the plastic bases that come with the figures.
or 2mm laser cut MDF from Warbases (UK) for everything else (in particular 28mm).
17/08/2015 at 08:27 #29375Iain Fuller
ParticipantAll my bases are MDF from Warbases, for my 18mm Napoleonics I use 2mm and my 6mm Moderns have 3mm.
Apart from the great value for money and speedy service that you get from them they are happy to knock up anything that you ask – couldn’t recommend them enough.
17/08/2015 at 09:22 #29384General Slade
ParticipantI always used to use 0.8mm ply bases that I bought from Litko. Recently, to save money, I started cutting my own bases from sheets of ply I bought from an eBay supplier. However, it is a job I hate doing (I seem to cut myself as much as the wood) and if I could afford it I would go back to ordering from Litko.
17/08/2015 at 15:01 #29402McLaddie
ParticipantPlastruct 1mm styrene sheets
For 2mm through 28mm, that is what I use. Evergreen Scale Models has Sheet Styrene [ 12″ X 6″] that is scored on one side in squares, half, quarter or one-eighth inch. I use the 1/4″ square “Sidewalk sheeting #4516′.
It is easy to size and cut uniformly. With the scored side up, silicon spackle holds well. It is around $3.50 per sheet, which isn’t any more expensive than the alternatives mentioned and/or easier to size and make stands. One sheet will make 144 1″ X 1/2″ or 60 1″x 1” stands.
17/08/2015 at 15:04 #29404MartinR
ParticipantArtists mounting board, with magnabase on the back (to attach to the steel paper in my A4 box files).
Cheers
Martin
17/08/2015 at 15:38 #29408Don Glewwe
ParticipantSheet polystyrene, most commonly accessed at the local hardware or DIY store in the form of ‘for sale’ signs.
Not thick, but then I admit to being in the minority of gamers who view stands as things to keep figures upright (and as innocuous as possible) rather than handling tools to protect precious paint jobs and/or diorama-style display plinths.
Storage/transport issues solved by magnets are addressed with an embedded K&J disc.
PS – I admit to being a recent convert to clear stands for 1:1 basing. The visual impact is, imo, preferable to a base’s distinct terrain clashing with whatever site it may be placed during a game.
This reply was modified 5 years, 6 months ago by
Don Glewwe.
Don Glewwe.
https://brawlfactory.net/
17/08/2015 at 16:17 #29414Spurious
ParticipantPost-1990 1p&2p coins. The date being important due to being reasonably magnetic from that point onwards.
Plastic slottabases where required. I’d like to try clear bases but there’s so many awkwardly balanced miniatures that need their little plinth or tab for holding up. Or it’s just a big thing that’d be a git to remove, like the rectangles all the Empress modern Russians are attached to (or any 6mm infantry for another).
18/08/2015 at 15:57 #29496McLaddie
ParticipantWhatever the material, I tend to like bases that disappear on the table, which would be matching the mat/terrain, thinness and color.
