- This topic has 7 replies, 4 voices, and was last updated 6 years, 9 months ago by
paintpig.
28/09/2015 at 13:06 #31720
Iain Fuller
ParticipantHello all,
I’m having a bit of techno-mare with my blog and could do with some advice.
How do you get a WordPress blog to show Google-based blogs that you follow?
Many thanks,
Iain
28/09/2015 at 13:37 #31730Mike
Keymaster28/09/2015 at 15:19 #31734Norm S
ParticipantI can only tell you how blogspot does it and I am guessing that WordPress has a similar process.
Basically after signing in, I go into the layout section. There are several partly highlighted boxes around the screen that have the word GADGET in them. This just means that it is an allocated area that is free and can be used to add a PLUG-IN.
Plug-ins give you all sorts of extra things around your screen, such as a FOLLOWERS section or a VISITOR COUNTER or a LIST OF BLOGS THAT I FOLLOW or TOP 5 VISITED POSTS FROM THIS BLOG etc.
Just select the plug-in that you want.
Hopefully WordPress is similar.
28/09/2015 at 17:02 #31739Iain Fuller
ParticipantThanks chaps –
Mike – yeah it is supposed to be an auto-list type thing, I have followed their instructions but it doesn’t seem to want to play.
Norm – thanks for the tips I’ve basically done that but in the WordPress stylee, it is still being a git though!
28/09/2015 at 17:04 #31740Mike
Keymaster03/10/2015 at 04:49 #31998paintpig
ParticipantI have this feature, hang tight and I will check which widget you need. From memory you will need to obtain the feed url but none of this is overly difficult, hell I did it!
Slowly Over A Low Flame03/10/2015 at 09:34 #32001Iain Fuller
ParticipantThanks guys, had a dig about and figured it out in the end using your pointers.
Mike, it was a list thing that I had to paste in URL’s – bit of a pain that they make you do that for non-Wordpress things but not too much bother.
03/10/2015 at 16:58 #32005paintpig
ParticipantI take it you found it then? The RSS widget, you will need to install the widget for each feed you wish to show. To find the rss or atom feed is usually pretty easy unless the site has deliberately deleted them from being shown. Stick with WP it is very versatile (particularly the themes) once you get your head around it.
Slowly Over A Low Flame -
