Home › Forums › Air and Sea › Naval › Scratch-built galley
- This topic has 20 replies, 5 voices, and was last updated 7 years, 6 months ago by
Deleted User.
17/12/2016 at 01:47 #54026
Deleted User
MemberI’m going to try to build a few boats for my Bronze Age armies: starting out with a Mycenaean/Minoan galley (or two: always just as easy to build a few as to build one). They’ll be “waterline” models, in a simplistic (but not unattractive) style.
20mm, if that makes any difference but I’m looking for any on-line material that may help me.
donald
17/12/2016 at 02:09 #54029Rod Robertson
ParticipantOchoin:
Here’s a PDF to peruse:
here is a very useful page I used to paint up some Bronze Age ships for a buddy of mine:
http://www.salimbeti.com/micenei/ships.htm
Cheers and good building.
Rod Robertson.
18/12/2016 at 03:52 #54097Deleted User
MemberMuch appreciated, Rod.
donald
20/12/2016 at 11:57 #54196Deleted User
MemberRe; boat building.
I’m making progress. The hulls, carved out of balsa look good but despite sanding are a little rough.
Would coating them in white (wood) glue help?donald
20/12/2016 at 14:33 #54199Patrice
ParticipantThe hulls, carved out of balsa look good but despite sanding are a little rough. Would coating them in white (wood) glue help? donald
Stripes of thin paper (cut from a newspaper) glued and generously coated with white glue mixed with cheap acrylic paint can be a solution; sand again when dry. I did this for pirate ships (on modified Heller Nina plastic hulls). The paper stripes can even look like planks.
https://www.anargader.net/20/12/2016 at 17:10 #54212Rod Robertson
ParticipantOchoin:
A light wash or two with 50% diluted water-based white acrylic paint, allow the coats to dry completely, then re-sand with fine-grain sand paper and repeat until smooth. Doing the same with latex-based diluted white glue should produce similar results if you dilute the glue before application. That’s what I have done in the past. If your worried about warping or deformation just be careful not to inundate the hull with the diluted paint. Patrice’s papier-mache method would also likely work but I have never done it so I will not comment on its efficacy. Good luck and keep us posted.
Cheers and good gaming.
Rod Robertson.
20/12/2016 at 22:28 #54238Deleted User
MemberGentlemen: thanks for the suggestions.
I’ve never built anything like this before. It’s been quite enjoyable so far.
One of the positives is the galley is simplified, by virtue of it being a usable, wargames’ model. Also, even with sources such as Salimbeti, there is a degree of lea-way in design because of the tenuous nature of the sources.
I’m currently “designing” a removable mast & sail (which I think will be lashed to the top spar for simplicity).
The pair of galleys should get a “run” next year with my Sea Peoples.
donald
21/12/2016 at 00:51 #54239kyoteblue
ParticipantLet us know how it goes, and please if you can, post pictures.
24/12/2016 at 12:53 #54441Deleted User
Member24/12/2016 at 21:18 #54476Rod Robertson
ParticipantOchoin:
Lovely work and the result is most impressive. Do not fear to be gawdy. Some Bronze Age ships were lavishly decorated with carvings which were very colourfully painted and lacquered. Go hawg-wild if the muses move you to do so! Thanks for posting your progress and best wishes for the season.
Rod Robertson.
24/12/2016 at 22:46 #54479kyoteblue
ParticipantVery good looking !!!!
24/12/2016 at 23:47 #54482Deleted User
MemberOchoin: Lovely work and the result is most impressive. Do not fear to be gawdy. Some Bronze Age ships were lavishly decorated with carvings which were very colourfully painted and lacquered. .
Thanks, Rod. I seem to have some spare time after another run-in over at TMP 87))).
My research took some weird turns: amongst other twists into the wet-world of Teredo navalis.
“pine trees can become riddled with tunnels within 16 weeks of being in the water and oaks within 32 weeks, with whole trees 30 centimetres (12 in) in diameter being completely warped within a year.”
I figure you’d be lucky to keep a vessel afloat for 2-3 years? So decoration may have been rather superfluous at times?
At any rate, I decided plain & warlike would suit.
donald
25/12/2016 at 01:00 #54484kyoteblue
ParticipantMost of these ships spent more time out of water than in. They were rolled up on beaches when not in use and repaired. So some could be rebuilt for years of use.
25/12/2016 at 07:44 #54488Rod Robertson
ParticipantOchoin:
No time to talk now but you might find this interesting:
http://www.deguwa.org/data/File/Bohrmuschel-Mueller.pdf
Cheers and Merry Christmas/Season’s Greetings.
Rod Robertson.
25/12/2016 at 09:20 #54497Deleted User
MemberNice point, KB. I hadn’t considered this, which is dumb as I see these galleys as glorified Canadian canoes.
Rod: you’d have to be a complete Geek to like that article. I love it!
donald
25/12/2016 at 16:54 #54510Rod Robertson
ParticipantOchoin:
Geek On!
Rod Robertson.
03/01/2017 at 05:36 #54871Deleted User
Member03/01/2017 at 05:37 #54873kyoteblue
ParticipantAll right !!!
03/01/2017 at 11:04 #54884Victoria Dickson
ParticipantVery nice. 🙂
03/01/2017 at 14:14 #54894Rod Robertson
ParticipantOchoin:
The galleys are lovely. Well done! If they are for 20 mm minis, what are the dimensions of your ship models? Will you base them or leave them free-standings?
Rod Robertson.
04/01/2017 at 13:05 #54950Deleted User
MemberIf they are for 20 mm minis, what are the dimensions of your ship models? Will you base them or leave them free-standings?
Rod: about 9 inches long. Yes, they’re for 1/72-20mm gaming & will be placed on the “terrain” (well, the “water”, obviously).
We use the Field of Glory rules & always keep within the same Army book. So the natural enemy of the Mycenaeans would be the Hittites….but I don’t have any. So my burgeoning Mycenaean army (about 800 points at the moment) will take on the NKE of which I have over 1000 points. Latest unit (just finished) was these:
I have Caesar & Newline NKE chariots but I like variety. When I acquired a set of the old Atlantic Egyptian chariots, I realised they needed work……
new wheels
axle replaced with a longer length of wire & moved to rear
additional detail on the chariot body
driver given a whipStill a bit “toy-like” but not too bad.
I’d love to move into a campaign with the period but FoG seemingly reneged on their earlier promise to publish campaign & siege rules.
donald
