- This topic has 3 replies, 3 voices, and was last updated 1 year, 3 months ago by .
Home › Forums › Ambush Alley Games › Force on Force › SMAW Question
In the rules a SMAW is listed under “Infantry Support Weapons” and not “Infantry Anti-Tank Weapons”, but it does have an AT rating of 2 and it is not a guided missile. Since the SMAW has an AT rating then I assume the rules for “Infantry AT Weapons Vs Vehicles” apply, even though it is not listed as an Infantry AT weapon. Is that correct?
So if I have a SMAW Team firing at a BTR-60, the SMAW Team would roll 4D FP (2D AT rating + 2D Team bonus) and the BRT-60 would have 3d6 defense dice, assuming a front armor hit. Then since the BTR-60 is considered a Light Vehicle, if the SMAW team scores a hit they would roll on the Light Vehicle Class Damage Table, under the Heavy Gun column, with a +1 die shift for each success after the first.
Or, because it is not classified as an “Infantry Anti-Tank Weapon”, does it only get 1/2 FP against Light and Medium vehicles?
All is ok. As you said is an anti tank weapon.
It’s classified AP:3/AT:3 (H) and it’s a heavy support weapon.
Then you roll on the Light Vehicle table, Heavy Gun column
Only Small Arms halved their fire.
Thank you!
.. if I have a SMAW Team firing at a BTR-60, the SMAW Team would roll 4D FP (2D AT rating + 2D Team bonus) and the BRT-60 would have 3d6 defense dice, assuming a front armor hit…
Just noticed this example – Bob, you have it right, though it’s not clear from the rules if you should get a +1FP if within optimum range, I play that you can.
Stats for SMAW (Appdx 1 p. 134 FoF base rules): AP:4/AT:2 (H) +1 positive die shift to FP against buildings.
