Home › Forums › Terrain and Scenery › Cutting and storing terrain tiles
- This topic has 8 replies, 6 voices, and was last updated 3 weeks, 6 days ago by Mike.
05/04/2024 at 14:32 #196808StugParticipant
Hi. I am not sure yet if I should use a cloth or tiles for my terrain. For those of you that are using tiles, can you show me (with pictures) how to store your tiles?
I also want to know what is the best way to cut perfect 2 x 2 tiles. I have a Proxxon but I don’t think it will be useful because of the size of the tiles.
Thanks for your help!
05/04/2024 at 21:32 #196841LogainParticipantI cut mine on a tablesaw – most big lumber/hardware will cut them for you if you ask. I use 1/8 mdf with a piece of foam insulation glued on top, both cut to the same size. I’ve seen both mdf and foam sold as 2×2 pieces here in the States, labelled as “project panels”. But I’d bet you could buy a full sheet (4×8) of each and have them cut for a fraction of buying pre-cut panels.
Storage is in a stack in the closet with a piece of fabric in between to minimize scratches.
05/04/2024 at 21:58 #196843StugParticipantI cut mine on a tablesaw – most big lumber/hardware will cut them for you if you ask. I use 1/8 mdf with a piece of foam insulation glued on top, both cut to the same size. I’ve seen both mdf and foam sold as 2×2 pieces here in the States, labelled as “project panels”. But I’d bet you could buy a full sheet (4×8) of each and have them cut for a fraction of buying pre-cut panels. Storage is in a stack in the closet with a piece of fabric in between to minimize scratches.
When storing a tile that has trees and buildings glued on top, how can you prevent those trees and buildings to break when you add another tile on top?
05/04/2024 at 23:40 #196847Mr. AverageParticipantUse a strip of styrofoam on each side of the tile and stack on that instead of directly on the tile. Or, the more object-intensive version would be to build a rack that spaces them out for you.
06/04/2024 at 01:24 #196852StugParticipantUse a strip of styrofoam on each side of the tile and stack on that instead of directly on the tile. Or, the more object-intensive version would be to build a rack that spaces them out for you.
Thanks. Great idea.
06/04/2024 at 07:29 #196860LogainParticipantI never glue trees or building to terrain boards. I always base them separately – then you can reposition them or swap out pieces to gain a great deal of more variety out of a board. It is also easier to store and costs very little time or money over fixing them to the boards. I typically have a couple standard sizes in mind (e.g. 8 inches, 6 inchs, 4 inchs) for building/forest footprints and plan locations that can accommodate them on the boards.
06/04/2024 at 11:56 #196871Don GlewweParticipantI never glue trees or building to terrain boards….you can reposition them or swap out pieces to gain a great deal of more variety…also easier to store…
I agree wholeheartedly with this. Using the rigid insulation foam for tiles* allows me to pin my terrain (rather than base it, which eliminates ‘extra’ footprint) which gives, as Logain mentioned, great flexibility for layout. Storage is a box with a sheet of foam into which the items are pinned -if a deep box, multiple layers can be stacked as per Mr.Average‘s spacers.
*I use the boards under cloth, but the principal applies equally well to ‘finished’ boards(?)
06/04/2024 at 13:35 #196878PatriceParticipantI never glue trees or building to terrain boards. I always base them separately
Using the rigid insulation foam for tiles allows me to pin my terrain
Yes and yes. I put very thin nails under most trees to pin them in the boards. Some other trees on bases, and the houses and fields, are also placed on the boards where needed for each game.
I just need a wall. 😉 😉 😉
https://www.anargader.net/06/04/2024 at 15:08 #196880MikeKeymasterI never glue trees or building to terrain boards. I always base them separately – then you can reposition them or swap out pieces to gain a great deal of more variety out of a board.
This.
