- This topic has 15 replies, 4 voices, and was last updated 9 years, 1 month ago by War Panda.
02/03/2015 at 09:28 #18824War PandaParticipant
Just tried out some of the proposals to modifying a mainly Bolt Action model just to see how some of the changes felt. I didn’t actually play the infantry turns but I recorded how much activity took place between tank activations.
Modifications included a Joker Dice which ended the Turn. I played that any inactivated infantry could go on ambush or Down or armour could go overwatch or reverse d6 inches
Tanks were on separate die from the infantry. One Sherman and a Stug. But Stug had 2 dice as it was Elite. Sherman 1 as was Reg.
Appropriate Skills possessed and used:
Stug Commander have Tank War Skill “Eagle Eye”
Stug Gunner has “Snap Shoot” these could be used once in the game
Activation of a Skill required a successful Skill test (roll lower than Troop Skill Level. Stug 10 Sherman 9
Movement rates are random. Tracked move on road with 4 d6’s full speed…
Ger Infantry Unit: Lt Blue
Stug had two die: Grey
Sherman: Brown die
Sherman has activated this turn already. The Stug is on the other side of town to the right and out of sight of the Sherman
First Turn ends only after two infantry activate. All units can go on Overwatch.
Sherman goes on Overwatch
Stug’s dice comes up first!
Stug decides to Advance (Move half pace and fire with penalized modifier) Rolls 2 d6’s
Rolls 2x 2 =only 4 inches…
But it’s just enough to get him on the street and in view of the Sherman…
They’re just short of 30 inches
This is less that half range for the Stug but just over for the Sherman…
The Sherman declares he will react fire to the Stug’s movement (he’s on Overwatch)
The Stug responds by playing his Eagle Eye Skill…which mean’s he can fire first if he successfully rolls a Skill Test…Veteran so 10 or less with 2 d6’s
That’s a pass…Stug will shoot first…Base 3 chance to hit. +1 because Stug’s just moved and +1 because he’s slightly unsighted with a burning 251 in the way 5 or 6 will hit
Rolls a four…missed
Sherman breaths a sigh of relief and can now fire straight back (remember he has an overwatch shot)
Sherman open’s fire…he’s stationary but unlike the stug he’s over half range so that’s a +1 and the burning half track between them means a 5+ to hit
Rolls a six…a hit
Rolls a 4 +5 for the 75mm damaging the Stug with a 9 ….
but it’s a -1 for long range for the Sherman so just falls short of getting the required 9 or more…it strikes the front of the stug’s armour with no effect
Lots of infantry dice before finally the Stug is drawn (remember the Stug has two dice to the Sherman’s one)
Another shot blasts from the Stug’s cannon…needing 4,5, or a 6 now because it hasn’t moved
4 means a hit on the Sherman
A 4 on the damage dice means it’s received at least some damage…follwed by a 3 and on the chart it means the Sherman’s immobilized and is pinned…it’s also lost it’s action for this turn.
Also means any further damage will destroy the Sherman!
Next Command dice drawn is the Stug …he’s hit already so I give a 1+ to hit…so he’ll hit on a 3,4,5,6
Rolls a “one”…lucky boy
Sherman’s die but he’s pinned so needs to roll and 9 or less – 1 for the pin so 8 or less…rolls a 5, the pin is removed and the Sherman opens fire
Sherman fires back
Needs a 3+ to hit…(it’s hit the Stug already so +1)…gets a five followed by a 6 for damage +5 for the 75mm meaning an 11 -1 for range 10 thats still damage but not massive
It’s hit and has penetrated but needs to…roll on the damage chart
5 on the damage chart means the Stug explodes into a violent mess of steel and screams
The Sherman has some how survived…well at least for now…it is immobilized for the rest of the game…
Well I realize these rules may not be for everybody and the ranges may seem questionable but this felt very satisfying and I loved the to and fro of it….I played the dice as rolled and was kind of amazed how it all worked out…
Also there was a bazooka available to the US and a PS available to the Germans so you never know how it would have turned out with the infantry running about. It would have been difficult to get each of them within range of their respected targets however
One question: If a anti-tank weapon has hit a target that doesn’t move should the nest shot be an automatic hit or what kind of modifier?
“The great Gaels of Ireland are the men that God made mad,
For all their wars are merry, and all their songs are sad.”02/03/2015 at 11:01 #18828Rod RobertsonParticipantThe War Panda:
Very cool interaction and very tense too. Perhaps the StuG should have suffered an additional +1 to hit on its first shot only due to not having seen the Sherman at the start of the turn?
You asked:
“One question: If a anti-tank weapon has hit a target that doesn’t move should the nest shot be an automatic hit or what kind of modifier?”
My inclination would be to give a +1 to hit if the target does not move and the firer does not move for the next shot.
Cheers and great gaming.
Rod Robertson
02/03/2015 at 14:50 #18832War PandaParticipant“Perhaps the StuG should have suffered an additional +1 to hit on its first shot only due to not having seen the Sherman at the start of the turn?”
Yeah I forgot about that and I think it makes sense for both tanks to be penalized in the first turn (in some way. And incorporating it into the “to-hit” makes most sense. My worry Rod is there’s already going to be a +1 for moving into position…will a tank want to risk it at all. And perhaps thats the point….wasn’t that the case in reality anyway.
What about the point Jack makes about penalizing a stationary tank rather than the moving one?
***Edit: I might move this discussion back to the main thread actually***
For all their wars are merry, and all their songs are sad.”02/03/2015 at 16:13 #18837Ivan SorensenParticipantI don’t have anything to add rules-wise but the zoomed in photo’s looks great. Got a little Saving Private Ryan feeling going on there.
02/03/2015 at 16:29 #18839War PandaParticipantThanks Ivan 🙂 Maybe a Little More Like Saving Ryan’s Privates after the Stug’s last roll 🙂
For all their wars are merry, and all their songs are sad.”02/03/2015 at 16:30 #18840Ivan SorensenParticipantAs an aside, is there a chance of the crew bailing out when the tracks get hit?
Should there be?
02/03/2015 at 17:00 #18843War PandaParticipantImportant Notice and Disclaimer
Absolutely no animals were killed or hurt during the making of this AAR
Well…absolutely not very many…
Maybe a cow or two…
And a couple of horses…but no more than 4 cows and a couple of calves and there was that cat but in all honestly he’s got 8 lives left
The Sherman did MG a dog pound before he turned onto the main street but it wasn’t very full and was mainly small lap dogs…
Actually now that you mention it there was this really funny moment when the FJ Flamethrower team gathered up all these kittens and…
For all their wars are merry, and all their songs are sad.”02/03/2015 at 17:01 #18845Ivan SorensenParticipantProbably Schnauzers and other Nazi dogs.
02/03/2015 at 17:03 #18846War PandaParticipantHa, ha that’s right…they had it comin
For all their wars are merry, and all their songs are sad.”02/03/2015 at 18:12 #18847Rod RobertsonParticipantHeel Hitler!
02/03/2015 at 18:13 #18848Ivan SorensenParticipantBoth Lenin and Churchill had cats.
Though FDR had like a million dogs, but they were patriotic, anti-fascist dogs I bet.02/03/2015 at 18:45 #18854Norm SParticipantI think the great strength of the rules is the absorbing story that it produces and these days, it is that sort of thing that I want my games to give.
In Advance Squad leader (ASL), perhaps one of the most notable of tactical games, after the first shot, you get target acquisition of +1 (though it is on 2 x D6 to hit) and second shot would generate a +2 target acquisition marker on subsequent shots as long as there is not a break (i.e the unit does not move out of LOS or the firer fires at something else).
I have no problem with the short ranges mentioned, as I have said before, we need to be in a cartoon world if we are to have all our toys on the table. The perception of ‘what is realistic’ is different for each of us, but I am guessing that what most gamers think is realistic is in truth only half way realistic and if you made Bolt Action more ‘realistic’, it would likely lose its story telling strengths by degree.
In reality, some things like the Jagd panther should never be in the immediate front line. Their training manual had them back 1500 – 2000m from the front, where their gun could easily engage, the lack of a turret didn’t matter too much and their thick armour made them pretty much immune to return fire from the ground…….. but we want them on the table!
Every rule set fills a niche or a gaming perspective, if that niche does not suit the player, then it is not to say that the rules have failed – it simply means the gamer needs to continue looking elsewhere.
Neil Thomas rule (One – Hour wargames) holds a position that rule designers can introduce a lot into their rules to make them more realistic and yet the outcomes can be close to his own rules that do have all those modifiers and other ‘essentials’ that apparently we can’t do without in rules. I am not saying that I fully embrace that, but I have a very substantial sympathy with such a point of view.
02/03/2015 at 18:47 #18856Ivan SorensenParticipantA few years back, I had downloaded a bunch of free WW2 games and played the same scenario with each set.
In the end, while we had games where we liked or disliked the process more or less, we had a hard time remembering which game had been with which system, because the outcomes weren’t all that different in the end 🙂
Er… I mean, all the other games are garbage, buy mine!
02/03/2015 at 19:29 #18860Rod RobertsonParticipantIvan:
i like and respect an honest and straight-forward man! I may or may not buy more of your rules but if you’re ever in Montreal, I will buy you some beers while we discuss wargaming.
Cheers and good sales.
Rod Robertson.
02/03/2015 at 19:31 #18861Ivan SorensenParticipantI’ll keep that in mind if I get the chance to visit our comrades to the North 🙂
02/03/2015 at 20:59 #18886War PandaParticipant“As an aside, is there a chance of the crew bailing out when the tracks get hit?”
In the rules it requires a second hit for the crew to bail but there probably should be at a least a chance of bailing
For all their wars are merry, and all their songs are sad.” -
