- This topic has 14 replies, 7 voices, and was last updated 6 years, 8 months ago by
alan.
12/11/2016 at 02:42 #52285
6mmwargaming
ParticipantHi all
Another project that i’m working on is a 1960-2000s Iraqis although there are some vehicles in there to help me morph it into Egyptians or a generic Arab army.
So far it is mostly Russian gear and a mix of 6mm manufacturers – Scotia, GHQ, H&R, Skytrex and CNC. I have T55, T2, T72, BMP1, BTR50, BTR60, ZSU23-4, ZSU57-2, SA13, SAU122, 85mm AT gun, MTLB and lots of softskins. I’ll continue to add to the pile but this should get me started! I’ve done some work on them and they are ready for painting. I’ve stripped and cleaned up them, replaced barrels with brass rod and Greenstuff, added stowage from more greenstuff and a few dozer blades.
Cheers
12/11/2016 at 02:43 #522866mmwargaming
ParticipantMy first batch of modern 6mm Iraqis is completed as I started this army a month or two back. Actually I’ve painted some tanks also, but I have decided to add some camo paint to them. These vehicles were painted using a spray can of Testors “Gulf Armor sand” followed by some highlighting and then off white drybrushing, and finally a dark tone vallejo wash. Not the best photos and they don’t show the contrast very well.
in the front row are BMP1 and UAZ469 jeeps, middle rows is MTLB engineers vehicles, Zil 157 trucks and SA-13. the back row is 2s1 SP122m guns and KRAZ 255 trucks
Thanks for looking
12/11/2016 at 21:39 #52314Thuseld
ParticipantI am tempted to get these and use them as fairly low tech Sci Fi armies.
Experiments here: http://inexperiencedmodelmaker.blogspot.co.uk/
Tranquil Stars updates: https://tranquilstars.wordpress.com
12/11/2016 at 22:04 #523156mmwargaming
ParticipantYou should have a look at Brigade Models Neo Soviet if you are after low tech scifi
13/11/2016 at 08:53 #52319Iain Fuller
ParticipantCracking set of kit.
I’ve been contemplating putting stowage on some of mine for a while now and I think you’ve just given me the impetus to do it.
13/11/2016 at 12:00 #52323Gaz045
ParticipantI like the finish, I’ve got loads to do and have been looking at the sprays to speed there process up.
The wash is just right, I have yet to perfect that bit!!
Incidentally, my lo-tech sci-fi unit has S-tanks and MTLB’s with Stalwart trucks……..and some 155 long tom artillery.
13/11/2016 at 12:20 #52324Rhoderic
MemberJust out of curiosity, what are the tanks with the double barrels in your first post? Excuse my ignorance as I don’t know the first thing about tanks. I just recall a discussion on a sci-fi forum (not TWW) over a sci-fi tank miniature that had a double-barrelled turret. A real-world tanker or tank mechanic in that forum seemed to find the notion ridiculous for reasons I can’t recall, so it would be interesting to me if it turns out that such beasts actually do exist.
14/11/2016 at 07:56 #52351Iain Fuller
ParticipantThey’d be ZSU-57-2’s.
Not tanks but SP twin 57mm AA guns, what the Soviets had before the ZSU-23-4.
14/11/2016 at 09:40 #52356Rhoderic
MemberAh, that would make sense. Thanks.
I did say I was ignorant about this kind of stuff
14/11/2016 at 10:26 #523606mmwargaming
ParticipantYes ZSu-57-2,but I replaced the barrels
14/11/2016 at 13:57 #52381Thuseld
ParticipantI already have a small force of Neo Soviets from Brigade Models. They have such a great look to them.
03/01/2017 at 07:26 #548766mmwargaming
ParticipantWork has slowed down considerably but I recently finished a batch of modern British 1/285-1/300th.
Chieftain Stillbrews and Warriors IFVs by Heroics and Ros and GHQ FV432s with Peak turret.
03/01/2017 at 08:45 #54878Mike
Keymaster05/01/2017 at 00:33 #549856mmwargaming
ParticipantI used to base them all on thin steel and then store them on magnetic sheet. But I dont like the look of green bases driving they towns etc. Infantry doesnt bother me strangely enough!
15/01/2017 at 18:05 #55672alan
ParticipantVery nicely done.
May I ask, what is your technique for replacing the gun barrels with brass rods? What diameter of rod do you suggest and how best to drill into the turret without damaging it?
Alan
