- This topic has 2 replies, 2 voices, and was last updated 9 years, 8 months ago by .
Home › Forums › Terrain and Scenery › Clear Casting Material for Those Craft Store Gems
I’m looking to cast some semi-transparent icy sci-fi terrain. I plan on casting a lot of walls for a sort of ice-maze with those glass gems common at craft stores embedded.
I could do it with resin, but perhaps there is a cheaper casting material as it does not need any detail or even a lot of strength. As my terrain will likely fill 2 square feet when complete, cost of the material could prove significant.
This is what I’ve used in the past…
Any better ideas?
You know, fightin' in a basement offers a lot of difficulties. Number one being, you're fightin' in a basement! --Lt. Aldo Raine
Prince August FX water effects? but it’s not cheap if you need a lot.
I have also thought about the translucent resin panel that you can find in some shops; some are very thin (but i did not try yet).
I think cost will prevent hobby water effects, but I have used a similar DAP clear silicone caulk for much the same thing. It would possibly work if I cast in layers and smeared the surface after the bulk set up.
I’m unfamiliar with “translucent resin panels.”
Thanks for the input.
