- This topic has 26 replies, 9 voices, and was last updated 8 months ago by
Guy Farrish.
19/01/2023 at 14:47 #182402
Guy Farrish
ParticipantI paint figs, but I’m not a painter. In the same way sawing up wood, screwing it together and staining it to make my bookcases (30 something years ago and still going strong) doesn’t make me a carpenter.
Having said that, seeing that Pendraken is now selling the Vallejo Xpress range filled me with enthusiasm and I was working out what to buy when I suddenly thought…does this make sense with figures below 28mm?
Most of my armies, certainly the ones I am buying large numbers of figures for and adding to now, are 10mm and 6mm with a few 15mm and 2mm for good(?) measure.
I can see GW Contrast, Army Painter Speed, and Vallejo Xpress paints working with largish areas of the same colour on 25/28/32mm figs but I wonder about the effect on smaller figures.
Any experience out there? Logic suggests stick with current methods but I’m always open to evidence based change.
19/01/2023 at 14:55 #182403Mike
Keymaster19/01/2023 at 14:56 #182404Mike
Keymaster19/01/2023 at 15:08 #182406Guy Farrish
ParticipantI was thinking this having just finished painting some 30 Years War Lt Cav and wondering if there was an easier way. (As I hinted, I paint to play, not play to paint).
Leon posting the note about availability of the Vallejo paints made my little heart skip, but then I thought of how many colours I use on these non standard (un)uniformed beasties and wondered if there was a point at this scale/size.
Yours look great, but then you are a painter.
Did the wizard/mage character get the same treatment?
19/01/2023 at 15:12 #182407Mr. Average
ParticipantI have found Speed Paints useful for big blocks of color but they still need detailing, particularly at smaller scales. For my 6mm scale troops I have simply not been satisfied and prefer my usual three-layer process even though it’s much longer to do. For 3mm scale, I have found them very handy for basecoating, and for big block color schemes like camouflage, however, as well as for coloring bases.
19/01/2023 at 15:13 #182408Mike
KeymasterDid the wizard/mage character get the same treatment?
Noooooo, that was about 4 hours of blending and mixing and doing it the old way.
It may be worth if for horses if you use many of them?
19/01/2023 at 15:21 #182409Mr. Average
ParticipantThe Army Painter speed paints I’ve found to be a little more stable to apply by the way – they don’t run as easily. So for example in the little infantry bases here I did the base first leaving the infantry white primed, then added their color second, and that worked well – the paint didn’t just go all over the place like a wash.
19/01/2023 at 15:31 #182410Not Connard Sage
ParticipantToo much fannying about for 6mm. Block colour, ink wash, paint the detail bits (that one’s the ball ache). Repeat…forever.
…or do what I did, pay to have the damn things painted 🙂
19/01/2023 at 15:59 #182414Steven Francis
ParticipantI have yet to cycle back around to 6mm/10mm as I am working though my 40k and Bardsung bits at the moment… But I think using the right colours of speed/contrast would covet the basecoat, shade and highlight of smaller models well and then you can derail on top. But I think it would only work well for low colour counts… So space marines… Good call as one armour colour, then detail. Imperial Guard… With the skin, uniform and all… Not so much…
But I have a back burner project of Epic orks and may try speed paints on them.
19/01/2023 at 17:03 #182416Mr. Average
ParticipantInteresting that you mention Space Marines – I also think they’d be good candidates for contrast paints with their (usually) solid base color, but they definitely need highlighting, as a real “highlight” is not necessarily just a version of the base color with white showing through – take red for example, it generally works way better with orange highlights rather than pink. So it’s worth some thought and planning.
19/01/2023 at 19:53 #182420Tony Hughes
ParticipantAs I mostly use inks for washes I need to use quite weak washes to prevent the ink drying glossy. I wanted a stronger wash for some 6mm vehicles (really it should be called a glaze) and tried a mix of ink with matt medium (W&N stuff but I also got same results with Liquitex later) and it behaves just like they describe in the videos of this fancy, expensive stuff. I tried a similar method to tint the armour of some 6mm Sci-Fi power armour from Brigade Models and was very happy with the result. No problem with coats bleeding or running into following washes or paint.
It wasn’t much use for most of the infantry I painted but it worked well on some cloaks. Best effects were definitely on vehicles. I’m going to try it out on some 10mm in my next project and see if it speeds up painting some Arab units.
Might pick up some samples of the new Vallejo stuff at York as I need a restock of a few paints as well as a pre-order from Pendraken.
19/01/2023 at 22:38 #182424Tony S
ParticipantI thought the same thing – that contrast paints were optimized for 28mm. But I started using Contrasts for 15mm horses, was very, very played with the results. I’ve begun using them for a most of the 15mm human figures now, and am pleased with the results overall. However, the smaller details and flesh I still use traditional paints as there doesn’t seem to be enough surface area or relief for the Contrasts to really work in my opinion.
Haven’t tried it with 6mm, but I wasn’t too keen on the single 10mm figure I tried it on. I went back to my usual 10mm black undercoat, and then paint as usual.
I was also very interested in Pendraken’s Vallejo announcement, and will try a few in my next order.
20/01/2023 at 08:51 #182432Giles Dorrington
Participant10mm using a mix of contrasts and speed paints (plus some vallejo metal color). IMHO they’re actually better in the smaller scales as the lack of large surface areas eliminates staining and they’re easier to work with than normal acrylics (flow off the brush better and don’t require thinning). Only downside is they won’t always cover mistakes (depends on which one you’re using).
20/01/2023 at 11:44 #182448Mike
Keymaster20/01/2023 at 12:48 #182458Giles Dorrington
ParticipantNot quite. I used Game Color Pale Yellow to pick out the wreath on the shield (needed something with decent coverage to go over the green) and the spear shafts are Scale 75 Inktense Wood. However, the metal is partially contrast; Aggaros Dunes or Basicanum Grey over Vallejo Metal Color Silver. Also I should point out that it’s all over a zenithal highlight, which helps with the contrast.
20/01/2023 at 13:01 #182459Guy Farrish
ParticipantThanks everyone.
I suspect the key to the outcome is the skill and effort involved rather than the materials used.
Good painters (see all above) get good results with any method.
It seems that Xpress paints can (somewhat counterintuitively) produce good results on 10mm, but whether there is any saving in time to achieve that finish is probably debatable.
In the interests of keeping the brain alive with new things however, I shall try them on some cavalry to start with and see how it goes.
Thanks again.
(NCS’s answer, while cheating, is feeling quite attractive as I move into 17th century eastern European armies with all those ****** horses and multi-coloured cavalrymen.)
20/01/2023 at 13:06 #182460Not Connard Sage
ParticipantMy excuse is that my eyes aren’t much cop these days. I can manage 28s, but anything smaller is tricky 🙂
20/01/2023 at 13:41 #182462Guy Farrish
ParticipantMy excuse is crap painting!
I have painted in so many different styles as they came down the track I am stuck in a horrible mish mash of black lined, white/black/grey/red undercoated, washed, block painted, highlighted, dry brushed, wet blended, shaded, inside out, light to dark styles. (Neatness – yeah, that’s another problem).
So the idea of painting one coat over a light undercoat is a siren song. Hearing that, yes, it does work, but you need to do all the other stuff as well, makes me wonder if I shouldn’t just go back to block painting in Humbrol enamel.
20/01/2023 at 13:45 #182463Mike
Keymaster20/01/2023 at 15:29 #182465Giles Dorrington
ParticipantOne of my earliest modelling / gaming related memories is the taste of turps. When I was young I used to really like Cresta (a soft drink from the early ’70s). I used to keep my turps in an old Cresta bottle……I probably don’t need to draw you a diagram.
On the subject of contrast/speed paints and horse flesh a friend recommended a 50/50 mix of Army Painter Dark Wood and Hardened Leather speedpaints. I’ve tried it and it works very well.
20/01/2023 at 16:53 #182469Not Connard Sage
ParticipantOne of my earliest modelling / gaming related memories is the taste of turps. When I was young I used to really like Cresta (a soft drink from the early ’70s). I used to keep my turps in an old Cresta bottle……I probably don’t need to draw you a diagram. .
Was it frothy man?
20/01/2023 at 16:57 #182470Giles Dorrington
ParticipantThe Cresta yes, the turps not so much (although probably better for your teeth).
20/01/2023 at 17:26 #182473Steven Francis
ParticipantOn Mr Averages point about the tone of highlights, different undercoats can have a big effect on the look of the speed paints… So use a pale yellow under red or green to get a more tonal highlight. Still not the control of layers/blending but worth keeping in mind… But it does mean it’s less speed if you have 4 different base colours first!
20/01/2023 at 22:24 #182484OotKust
Participant10mm using a mix of contrasts and speed paints (plus some vallejo metal color). IMHO ….
They’re amazing when you use the blown up photo… cheers d
20/01/2023 at 22:26 #182485OotKust
ParticipantI paint figs, ,, Most of my armies, certainly the ones I am buying large numbers of figures for a…
C’mon Guy, aren’t you getting a bit old for buying heaps of new stuff..?
😉 dave
20/01/2023 at 23:23 #182490Giles Dorrington
ParticipantThanks. I’m really pleased with how they came out.
21/01/2023 at 00:24 #182492Guy Farrish
dave
Looking at burial at sea – think of them as ballast.
